Amp for LSis ?
bykes
Looking for recommendations on an amp for my future LSi9s, LSiC and LSiFX system. Not looking to spend a ton of money, but just something that will do the job at a good price. Something less than $1K
Thanks.
Thanks.
http://www.polkaudio.com/forums/showthread.php?t=56009
These for your front 3 would be unbelievable.
you won't have to worry about upgrade itus.engtaz
There are tons of threads on this forum regarding this situation. However I suggest you raise the amount you want to spend.
The LSI's perform best with lots of power. in the range of 200wpc & up. Even used, that costs more than $1K.
If you are not willing to spend the amount needed to properly drive the LSI's without risking them or your receiver, than look for another speaker.
Or you can snatch those Adcoms! WOW!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The NAD gear will work for you. I enjoyed the 2600/2700 power envelope series, they can be had used on Audiogon in the 250-450 range.
Its just one option of many, parasound would be another company to look at.
RT1
