Bi-amping using my NAD T773...awesome!!
2
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    Ah ha . . . I don't think we could call it bi-wiring either. . . so did Phil come up with something new?
    VR3 Posts: 29,405
    edited August 2007
    And to comment on the other poster....
    The tweeter may only use a few watts, because the crossover crosses over the signal.
    However, the amp is actually powering a 20 - 20hz signal until it reaches that crossover, then it is broken down. But the power is still working just as hard as before - even if it is just a tweeter.
    Thats what it comes down to with the crossing of the amps part...
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited August 2007
    Actually, the amp is still powering 20 to 20K, but it is not working as hard. The woofer section on the CSi40 is 4.5ohms, the tweeter section is 400Kohms. Don't know the actual measurements of his speaks, but they will also have much higher readings on the tweeter circuit compared to the woofer circuit. How much power do you think the amp puts out into a 400Kohm load? Very little.
  • pearsall001
    pearsall001 Posts: 5,251
    edited August 2007
    Maybe I'm missing something here. If the T773 can run all 7 channels at 110watts, & in stereo mode (2 channel...run 145watts) then if I'm taking the extra unused amp or unused power (surround back speakers) & bi-amping it with the power going to the fronts, how does that not increase the power going to my mains? I have speaker cables from the front channel going to the mid/woofer & speaker cables fron the surround back channel going to the tweeters. Running in stereo doesn't that make it 145watts to the tweeters & 145watts going to the mid/woofer? It seems logical, but then again what the hell do I know. It really doesn't matter how much the tweets & mid/woofer actually use (normal speaker usage is 10-12watts I believe) it's just that the reserve power is there when needed. I did email NAD & I'm waiting for a reply. Interesting topic for me, thanks for all the technical info.
    VR3 Posts: 29,405
    edited August 2007
    I have never in my life seen a 400k ohm tweeter?
    Every tweeter I've ever had in my speakers have been the normal 4 or 8 ohm load by themself? And draw upwards of 50-100 watts continuous.
    An amp will power a 20-20 hz signal regardless... it dosnt know what it is powering unless you tell it otherwise, which has to be done before the amp receives its signal. Not afterwards.
    If you send a 120 watt signal of 20-20hz, to my understanding, its always going to be a 120 watt signal of 20-20hz... that is until you put something like a crossover before the amp receives the signal...
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited August 2007
    I think you are putting 220 to each speaker....110 on highs, and 110 on mid/lows....Technically, those channels are still driving something, so the 145 rule would not apply....Just my thought......
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited August 2007
    Phil, Phil, Phil....look at the trouble you cause with your shenanigans. :)
    You should have just stated that "good, Nad, sound" and none of this would have started.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • hearingimpared
    edited August 2007
    Mike this stuff starts if someone mentions vanilla ice cream!!!!
  • Midnite Mick
    edited August 2007
    I don't know if it is my imagination, but this stuff seems to be getting worse around here lately.
    Consonance cd120T
    Usher CP 6311
  • WilliamM2
    edited August 2007
    Neither have I. I am talking about the entire tweeter network, including crossover. Do you have any speakers on hand with Bi terminals? If so, remove any jumpers, and measure each set of terminals. This does not give you a true reading, but it will demonstrate what I am talking about.
    But your not sending 120 watts, due to the higher impedence. The higher the impedence, the less power the amp will put out.
    heiney9 Posts: 25,430
    edited August 2007
    Vanilla ice cream tastes like chocolate.
  • pearsall001
    edited August 2007
    Mike
    I had to liven things up around here, it was getting too boring!!! :D Anyway, I'm still looking for the magic answer. I don't think anyone's put their finger on the answer yet, just a lot of theory & speculation. Any thoughts??
  • Systems
    Systems Posts: 14,873
    edited August 2007
    Technically you arnt biamping, you are just powering to like signals into two jacks.
    well its called passive biamping because the passive crossovers are still used.What he is gaining is some extra headroom.
    True biamping would have an amp crossed over to only runs the highs, and the other amp cut off from powering the highs -- so its doing all it can for each individual piece.
    "True"biamping using an active crossover that divides the signal before the amps has many more benifits than the passive version.
    Testing
    Testing
    Testing
  • Midnite Mick
    edited August 2007
    Nah, I am not smart enough for all this. Try it without the fancy bi-output and then with it. Listen to some very dynamic music at a high volume and let your ears decide. I just know if I like what I hear or I don't...I am simple folk I guess:)
    I personally think that all of their arguing over what is going on would be dependent on the design of this specific unit itself. I would sooner pose this question to Nad and/or someone that is knowledgeable of this specific unit if I really wanted to know.
    Glad you are enjoying things nonetheless.
    Mike
    Consonance cd120T
    Usher CP 6311
  • pearsall001
    edited August 2007
    Mike
    That's the first thing I did was to shoot an email off to NAD posing the question at hand. Then I posted here to get feedback on the same question. I got a lot of diferent takes on this bi-amping issue. I've read a lot of theory & speculation on the different answers here but I don't know which one or if any of the responses are correct or not. As soon as I hear back from NAD I'll post their answer (hopefully the correct one :D )
  • hoosier21
    hoosier21 Posts: 4,415
    edited August 2007
    more bad information from Vr3 :) read more type less
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Deadof_knight
    Deadof_knight Posts: 980
    edited August 2007
    It starts becuase we come running in here to check to see what everyone else wrote and to then say something in return hahaha it is entertainment and frustration all wrapped into one lil forum ! ;)
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2007
    New audio term warning!!!!!!!!
    I guess the NAD with two power supplies wired this way is giving him Separately Powered, Passively Filtered Biamping.
    Put that in your signature Phil!!
  • Deadof_knight
    edited August 2007
    Sweet Dennis !
    edited August 2007
    Dennis, they use the same power cord so in a sense NOT seperately powered :p:D :)
  • Dennis Gardner
    edited August 2007
    heiney9 wrote: »
    Unicorded...........
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    Chocolate ice cream tastes like chicken :p
    If he hears a difference, there must be a difference. None of you have accounted for the geographical differences in electron composition created by the earth's axial rotation. Depending on where the NAD power supply components are manufactured or the time of the year, they might have the denser molecular properties that are know by many audiophiles to create a sweeter tube-like sound and also enhance the ability of a torridal transformer to supply multiple channels of sound. ;)
    DKG999
  • hearingimpared
    edited August 2007
    heiney9 wrote: »
    Listen the merits of chocolate ice cream are obvious. It is well documented that most people like chocolate better than vanilla but eat vanilla anyway. Studies have shown that those who actually like chocolate better than vanilla but eat vanilla really love strawberry better but are ashamed to admit it. Now on the other hand a new study has come out that proves without a shadow of a doubt the butter in butter pecan ice cream can be toxic when mixed with the pecans but people who say they like butter pecan ice cream have no problem eating butter almond but with butterscotch syrup on it to counter act the toxicity of the butter in the butter pecan . . .
    . . .so what does this all mean . . . YOU ARE WRONG!
    :rolleyes: :rolleyes: :D:p;)
  • hearingimpared
    edited August 2007
    You did that already when you said it sounded wonderful!
    tonyb Posts: 33,069
    edited August 2007
    Far be it for me or anyone else to tell Phil what he hears.As long as it's good to your ears Phil,rock on bro.
  • madmax
    madmax Posts: 12,434
    edited August 2007
    Cant we all just go mono... ??
    madmax
    Vinyl, the final frontier...
    F1nut Posts: 51,713
    edited August 2007
    madmax wrote: »
    madmax
    Hell NO!
  • WilliamM2
    edited August 2007
    Well...with everyone going back to tubes and vinyl, I guess mono is the next logical step. Why not?:p
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    I'm NOT!!!!:D I have zero interest in going back to the old days.:D
    WilliamM2 wrote: »
    VR3 Posts: 29,405
    edited August 2007
    I didnt give misinformation. I gave partial information that wasnt complete.
    What I said was -- if you do not cross your amps over before they receive their signal, they are still processing and powering a full 20-20hz signal.
    Now, this is what I learned on this board ages ago, but the gentleman that told me this neglected to tell me that on a tweeter network, the amp will see a 400kohm load. Which, irregardless -- is still powering a 20-20hz signal, just at a nuch higher impedance...
    I didn't give wrong information, you are just being a jerk ;)
    To me, all he is doing is basically taking two 2 channel amps and running it into his speakers. Applying alot more power to each individual part. Which of course is going to give more headroom, but still wont have the advantages of active biamping.
    Makes more sense to me to just get one large amp ---
    But he is definitely applying more power - just not in the sense to me should be called biamping. But whatever. Passive biamping, sure sure...
