FXi3 Help!
Hi,
If I have a square area with a single chair on the back wall and two fxi3's beside it in each of the corners with the speakers facing the chair, and the speakers flush against the back and side wall, do I set the speaker to dipole or bipole? Also what is the best listening height?
Hope that makes sense.
Dan:o
Dan:o
I think Bananas are awesome fruit.
HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
http://www.polkaudio.com/forums/showcase/view.php?userid=81835
____________________
Post edited by 2michaud on
Don't think it really matters since your defeating the bipole/dipole effect by your installation. You really need the speakers mounted to your sides to take advantage of this speaker. That said, I would run bipole if this were my only option.
Bipole. With that location you don't really have a choice. Welcome to the forums.
Thanks guys, that helps my decision since the speakers look terrible in that spot anyway.
