Avel Lindberg transformer for AI-1 interconnect
woofiepaws
woofiepaws Posts: 224
edited August 2014 in Vintage Speakers
I need some help building an AI-1 interconnect.
Has anyone here used the Avel Lindberg transformers mentioned in the SDA Compendium, and if so, which model? Are there any differences between the two?
Has anyone had Avel make them a custom one?
I recently got hold of a pair of 1.2TLs that I really want to use with my Carver Silver 9ts. Strapping the negative terminals results in a horrible hum so I am afraid to even hook up a source at this time.
Thanks for any help,
Steve
Post edited by woofiepaws on
    F1nut Posts: 51,934
    edited August 2007
  • woofiepaws
    edited August 2007
    Thank you F1.
    That's a lot of info. The Avel seems to be the way to go.
    Another question: can the old cable be cut and the trasformer be wired in?
    The Compendium 2nd ed. schematics show the blade going to ground but the AI-1 building instructions on pages 65 and 66 say to use a seperate piece of cable from the transformer to the negative speaker terminal. Seems messy if one could use the pin-blade conncetor to get the job done.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2007
    The standard pin/blade cable does not have a wire running to the blades of each connector. If it did, it would be a simple matter to splice into the blade's wire and use that for connectivity to the negative speaker terminal. Since the back ends of the blades are fully encapsulated in hard plastic, you would have to drill through the connector ends to access them.
  • woofiepaws
    edited August 2007
    Thank you for your reply.
    So the stock interconnect has two wires inside with only one hooked up to the pins and the other just sitting there?
    Weird.
  • DarqueKnight
    edited August 2007
    No. Both of the wires are connected to the pins.
  • nspindel
    nspindel Posts: 5,343
    edited August 2014
    Wow, just noticed this thread under 'similar threads' in the group buy thread. Woofiepaws, I'm impressed! Almost 7 years since you posted this, and you're finally getting your Dreadnought!
