Cutting down sono sub?
MSALLA
MSALLA Posts: 1,602
I'm playing with the idea of cutting my diy sub down to 39" from 48". SVS told me the set-up I have now (16" x 48") is good for 16hz. It runs low but not alot of pressure. I read the specs. on the 20-39 and think this would be a better balance for music and HT. Any input on this guys?
I'm running a 12.1 svs plus driver, outlaw m200 amp in a room 12' x 25'. The room is NOT a dedicated sound room. It's my living room.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • Grimster74
    Grimster74 Posts: 2,577
    edited August 2007
    If I'm not mistaken, didn't you get the 12.1 from me, if so, how is it holding up? Come to think out it, I never got to see pics of your final project.
  • MSALLA
    MSALLA Posts: 1,602
    edited August 2007
    Yes I did. It's holding up great. I love the sound of it. I sm just second guessing my choice of dims. for the tube. I think 20hz would be low enough in range and I would get more pressure with the lower height.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I have the 12.1 also. I have noticed (through trial and error) that if the enclosure is too large, dB's are lost and trying to turn the amp up only over drives the driver to a point of over excursion.
    In my opinion I would not go with any enclosure larger than what SVS builds.
    39" tall should be plenty large enough. You could go shorter than that , like 36". With a 4" port 12-14" long
    I think the max cuft used for that driver is 4cuft. Any larger and you loose punch and dB's.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • MSALLA
    MSALLA Posts: 1,602
    edited August 2007
    I built the encloser at the recomendation of SVS's customer service. I can't remember his name, but he was a big help. It is almost a direct copy of the 16-48 ( the big boy/ I may have the # wrong). For the room size, I see most people running 2. I don't have the space for this.
    I have a 4" x 17" vent tube, do you think I'll have to change that?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    MSALLA wrote: »
    Like I said, I went through alot of DIY trial and error with the 12.1, and found 4cuft to be the best. In sonotube size, I would stick with 36-39" tall. That size it still digs very deep and has a very good dB output.
    Yes you might have to shorten the port a few inches, I'de say to around 14". I would not have the port more than 30-40% of the tube.
    Get back in touch with SVS, they can point you in the right derection, if you give them the size of the enclosure.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • MSALLA
    MSALLA Posts: 1,602
    edited August 2007
    Thanks for the help.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • SKsolutions
    SKsolutions Posts: 1,820
    edited August 2007
    MSALLA wrote: »
    The port is the tune, so to speak. The diameter and length correspond to a given frequency you are trying to reinforce. So it's not just a random thing to chop 3" off (although I've been asked to do this many times:D ).
    I'm sure you could find some DIY literature to help you look at the specs of the driver and the the volume of the new tube to come up with a new port tune (size).
    -Ignorance is strength -
  • rtart
    rtart Posts: 848
    edited September 2007
    I've found that the 25-31 is the best fit for movies and music (IMHO). I tried a pair of 16-48's, and settled on a pair fo the 25-31's. Most music and movies just don't have a lot of sub-25Hz material, and the 16-48's won't play as loud at the same power setting.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • MSALLA
    MSALLA Posts: 1,602
    I got the final reply from Tom at Svs (Top notch person, just a big help) and I am going to cut the tube to 39" and will keep the 4x17 port. I will looses some bottom end (from 16hz to 20hz) but will gain about 1.5 db and they think this will be a good trade off for the size of my room.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • MSALLA
    MSALLA Posts: 1,602
    edited November 2007
    Just got some spare time and I was able to cut the sub down. BIG improvement. The larger encloser was just too much for the size of my room. 2 of the 16 x 48's would have been the hot setup. But it's a living/enterainment room and 2 is just no visable. The bass really fills the room now and it still pulls pretty deep.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
