Refreshing Older Hafler Amp...
24
  • Systems
    Systems Posts: 14,873
    edited August 2007
    The voltage must atleast be the same but can be higher.You can use larger values of capacitance and will be benificial for the filter caps.But if it is increased too much you may have problems with fuses blowing at turn on do to increased current demand as the caps try to fully charge at turn on.You could just use a higher value fuse or better yet a soft start circuit.The 27000uf should be fine but are they insanely priced?I would get the ones you linked to at Mouser they should be easy to install as they are the can type like the originals and rationally priced.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    GV, I will copy my other post here from the amp thread.
    Thank you GV. Your saying you have the tab mount type? If you think that would work and if you have the right size, I'll take you up on that offer. I will replace both c1's as you recommended.
    C5 is electrolytic, C6 is Mica.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Thanks for all the help guys....
    Jake
    P.S See how easy and fun it is when you have friends who know what they are doing..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Do you think the Mica caps need replacing.
    I am not familliar with Mica caps.
    Really the only caps I am familiar with are crossover caps (Maylar, electrolytic, Solen, etc.)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I found a pic of one...seen these before
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    School just called I start in January...wooohoo!! Finances are set..
    Funny how things happen. I was sitting here talking to a electronics technician, who is here doing some work for the boss, about the project I was doing on my amp. The guy had no idea what I was talking about. He is a certified electronics techincian!! He said...we just change parts..not much bench work..
    The conversation started about me asking him if he knew what a Mica cap was, he had no idea. Then the phone rang, it was the finacial aid girl from college saying everything was aproved.
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Ok this is what I'm ordering from mouser.
    I wanted to go over the order before I comit to it.
    C1 replacing with:
    Nichicon Bi-Polar Aluminum Electrolytic Capacitors
    16V 10uF 5X11 - RoHS: COMPLIANT
    C5 replacing with:
    6.3V 470uF 10X12.5 - RoHS: COMPLIANT
    The questions I have. For the larger PS can capacitors, would you recomend larger than what is in there right now, or go with the same size? Would larger be helpfull?
    Also, the Mica caps, should they be changed as well or do they hold up pretty well?
    C7 and C10, the excact size is not avaliable with mouser, what size should I get?
    I was told that film caps should still be good sinc they dont break down as quickly.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    C7 and C10 are 100uF 80V caps. The closest mouser has is 100uF 100v. Would this be ok?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    heiney9 Posts: 25,445
    edited August 2007
    jakelm wrote: »
    C1 replacing with:
    C5 replacing with:
    It's best to go with the same capacitance rating on the PS if at all possible. Higher voltage is alright to a point and even a bit more capacitance is alright but going way over the cap value is not a good thing overall.
    Also if any of those electrolytics you have listed as replacements are in the signal path I'd reconsider using some other material makeup, unless they are odd ball size and value. Anything not in the signal path can be electrolytic if you want to save some $$$. This is just my .02c everyone has a bit different opinion.
    edited August 2007
    jakelm wrote: »
    Yes.
    edited August 2007
    I will also say new electrolytics are still better than the aged caps in the amplifier already. I'm a bit more anal so I would tend to replace the caps with non-electrolytic. But so far you are doing fine and will see some good improvement in the amp when you are done.
    Keep a fire extinguisher handy :D:p:D .
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Thanks H9.
    The C1 caps are in the input signal path.
    The C5 caps are in the loop feedback path.
    The C6 is also in the loop path , but it a Mica cap. I dont see anything like that at mouser. Or at least anything saying Mica.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    heiney9 wrote: »
    **** man...dont tell me that...lol:D :p :eek:
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    When you speak of non-electrolytic, ceramic or film is prefered?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I found the Mica
    This should work for C6 loop
    CDE Mica Radial Lead Capacitors
    270pF 500V +/-5% - RoHS: COMPLIANT by Exemption
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited August 2007
    jakelm wrote: »
    It's Murphy's Law.....if you have one handy nothing will happen.....if you don't....well........
    Seriously if you do things carefully one at a time and all the new parts are the same value or higher you won't have any issue's. But it's always better to be safe than sorry. :)
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    heiney9 wrote: »
    True... I have one...I will put it at my side.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I have to admit, this is alot more difficult than a simple crossover upgrade.
    But when its done and my friends come over (the very few I have..lol) they will say how well it sounds, I can just sit back, grin and go..yep..I did that...:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited August 2007
    jakelm wrote: »
    Yes it is and I for one have never tried it and I probably won't simply because I understand the "book" part of it but am terrible at applying that knowledge in an actual physical project. Speaker x-overs are my limit at this point. Plus I have very litle patience at times and with electronics, epsecially troubleshooting, you need lots and lots of patience. LoL
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    But you save a ton of $$ doing it yourself.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    Cool and quite a coincidence. I've been kicking around the idea of resurecting an old Hafler DH-180 for my bedroom rig. I did Musical Concepts upgrades to it back in 1989. This thread is definitely helpful.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    No offence to musical concepts, but for the price they want to referb or add their new board, you could buy a nice used amp.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    If not electrolytic in the signal path, then which of these would you select?
    Cap.JPG 20.9K
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    They dont have the size i need in a non-eletrolytic cap. I looked under polypropylene.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited August 2007
    jakelm wrote: »
    C1 replacing with:
    C5 replacing with:
    For C 1 I would go with a film cap.The Panasonic ECQ-E line from Digi Key would be a good choice if you can fit them on the board and cost $5.78 ea.Digi key part #EF-1106-ND. They are 10uf 100volt polyesters.
    The Micas should still be OK ,but I would replace C5.The Nichicon replacement you mention is fine.
    For the filter caps you can use bigger values and it does have performance advantages but like I mentioned previously if it is increased too much fuses may blow at turn on do to increased current demand when they first charge up.To be on the safe side I would replace them with the same value.
    Yes I do have some 10000uf 100volt Panasonic PC tab caps if you would like me to send you a few .Just let me know and I will send them your way.:) The only problem is you will have be creative when it comes to installing them.The can type would be easier.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Thanks GV.
    For the price I think I will just buy the can type that mouse has avaliable. But thank you for the offer.
    I would like to buy all parts form one place. Mouser can fill my basket. But it seems that electrolytic caps are the only type caps they have in my size.
    The Panasonic cap has a much highers voltage rating than the 16v in there right now. But since we are talking about signal path i guess voltage doesnt really matter right?
    So if I understand this correctly, the uF value is what to look for as far as signal is concerned and the voltage value is what to look for as for as current is concerned right?
    In other words, if the cap is in a signal path stay with the same or close to the uF value? Voltage can be as much or higher.
    If the cap is in a ac/dc current path stay with the same or close to the voltage value? uF can be as much or higher value?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    mhardy6647 Posts: 35,041
    edited August 2007
    "much higher voltage rating" is fine... just make sure the Panasonic caps will fit physically. Mouser should have links to product spec PDFs.
    The Panasonic film caps are OK sonically in my (albeit limited) experience. I used some as coupling caps in a Knight (Allied) 333 (a/k/a Pioneer SX-34) due to space constraints.
    Hope this helps.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I wish I had a milimeter measuring tool, to measure the caps in there right now...so I dont screw up and buy caps that are too large for the space.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    I will take a snap shot of the board tonight, to give you all an idea of how compaqued everything is.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    The Panasonic cap is a polyester cap.
    Mouser has a WIMA polyester cap 10uF 50v, which is smaller than the 100v Panasonic.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
