Quad Shield RG6 or Sub Interconnect
I am contemplating running Quad Shield RG6 for my sub (SVS PB12-Plus/2) and using "F" connectors w/RCA Jacks on each side for a cleaner look. Is there a big sound difference between homemade and a manufactured interconnect?
Post edited by Snagglepuss1318 on
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    RG6 will work just fine for sub duty, just make sure your terminations are done correctly. The only drawback will be the stiffness, otherwise you can always A/B another interconnect and make your own conclusions.
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2007
    I think RG6QS (quad shield) will work fine.
    Just make sure that the ends are terminated tightly.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • rtart
    rtart Posts: 852
    edited August 2007
    This is exactly what I did, and it works great. Makes a nice clean installation, and I can't help but think that RG-6 Quad is MUCH better than most high-dollar interconnects.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
