Quad Shield RG6 or Sub Interconnect
Snagglepuss1318
I am contemplating running Quad Shield RG6 for my sub (SVS PB12-Plus/2) and using "F" connectors w/RCA Jacks on each side for a cleaner look. Is there a big sound difference between homemade and a manufactured interconnect?
Post edited by Snagglepuss1318 on
RG6 will work just fine for sub duty, just make sure your terminations are done correctly. The only drawback will be the stiffness, otherwise you can always A/B another interconnect and make your own conclusions.
I think RG6QS (quad shield) will work fine.
Just make sure that the ends are terminated tightly.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
This is exactly what I did, and it works great. Makes a nice clean installation, and I can't help but think that RG-6 Quad is MUCH better than most high-dollar interconnects.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
