Matching Amps to Lsi series
askinquestions
askinquestions Posts: 80
edited August 2007 in Speakers
I finally just purchased a sunfire cinema grand 5 channel. I have read that in order to get a even match for the speakers, you should get comparable amps so as to not have a brighter or deeper amp. I have the lsi25's and soon to have matching lsic and lsifx. I also have some vintage satellite polks I'll use for surrounds. I got a deal on the 5 channel used and don't have the coin to have the 7 channel sunfire, so I am going to add a 2 channel amp. What would you recommend a decent 2 channel to go with the sunfire. Thanks......
PS: I can't wait to hear what the 25's are going to bring to the table with some power to drive them.......
Post edited by askinquestions on
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    The most important is using the same amp(s) to drive your soundstage(fronts/center).
    Are you using an AVR as a pre/pro? Have you thought about using the AVR to drive your surrounds?
    tonyb Posts: 33,068
    edited August 2007
    I'd second the Avr on the surrounds.If you want to match the sunfire though,look around for some older carver amps,can be had very cheap.
  • askinquestions
    edited August 2007
    I guess that would make sense. I just wasn't sure if I had the amp on 5 speaks if it would over power the surrounds. Thanks for the input.
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    This is where having a spl meter comes in very handy!
