Matching Amps to Lsi series
askinquestions
I finally just purchased a sunfire cinema grand 5 channel. I have read that in order to get a even match for the speakers, you should get comparable amps so as to not have a brighter or deeper amp. I have the lsi25's and soon to have matching lsic and lsifx. I also have some vintage satellite polks I'll use for surrounds. I got a deal on the 5 channel used and don't have the coin to have the 7 channel sunfire, so I am going to add a 2 channel amp. What would you recommend a decent 2 channel to go with the sunfire. Thanks......
PS: I can't wait to hear what the 25's are going to bring to the table with some power to drive them.......
Post edited by askinquestions on
The most important is using the same amp(s) to drive your soundstage(fronts/center).
Are you using an AVR as a pre/pro? Have you thought about using the AVR to drive your surrounds? -
I'd second the Avr on the surrounds.If you want to match the sunfire though,look around for some older carver amps,can be had very cheap.HT SYSTEM-
lsi 9's -
I guess that would make sense. I just wasn't sure if I had the amp on 5 speaks if it would over power the surrounds. Thanks for the input.
This is where having a spl meter comes in very handy!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
