Anybody using a component video switch to switch 5.1 analogs.
millerman 3732
millerman 3732 Posts: 1,488
edited August 2007 in Electronics
Pretty sure this has been asked before but anyway , What brand are you using? How much was it? Where did you get it? How does it sound? Any info you want to give I'm interested. Thanks.
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
  • millerman 3732
    edited August 2007
    None?.... Well then I shall be the first, J/K. Any way I picked up a switcher at Wal-Mart for $19 to switch between BD and HD-DVD analogs. Any opinions on this switcher before I open it? here's a link.
    http://www.keenzo.com/showproduct.asp?ID=934078
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    I used a regular A/V switch to switch between component video. Radio shack ones are highly recommended as they are the most basic switches out there and they are cheap to.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2007
    I use an Extron Crosspoint to push HD/ component content throughout my house: 8 input 4 output matrix switch. Picked mine up off ebay for about $200.
    Sounds like overkill for you application, but they make 4 in 1 out model, too.
    Backburner:Krell KAV-300i
