HD DVD/Blu-Ray..whichever
steveinaz
This high def DVD stuff is incredible, regardless of format. I was watching a demo disc at Sears the other day, it was awesome.
Question for the video gear-heads out there. If my DLP is 720p native, I'd probably want to run my high-def DVDP at 720p right? Wouldn't it be best to match resolutions?
I've got a 50" Samsung DLP that we sit about 8-9 feet from.
Post edited by steveinaz on
Well if your TV only supports up to 720P then definately setup your HD-DVD/BluRay player to play at that resolution otherwise it wouldn't be Hi-Def.
I can't think of a situation where you wouldn't want to run everything that is connected to your TV at your TV's highest resolution. If your TV supports 1080i, run it at 1080i. If it supports 720p, run it at 720p.
Please, someone correct me if I'm wrong but I think the highest resolution the TV allows for should always be used, correct?
Edit: Actually, just did some quick research (this was one article I saw) and it looks like that 720p and 1080i deliver the same amount of information but 720p will look smoother especially in action sequences. -
My Samsung supports 1080i, but it's native is 720p. OK, saw your edit. That's what I figured--progressive would be smoother. Thanks for the help bud.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Kris Siegel wrote: »Edit: Actually, just did some quick research (this was one article I saw) and it looks like that 720p and 1080i deliver the same amount of information but 720p will look smoother especially in action sequences.
1080i source is much, much better if your TV is 1080p. Whether to run 720p or 1080i to 720p set depends on the scalers on both the HD player and your TV. I'd set the HD player to 1080i and let your TV do the scaling. -
Thanks Sami, I guess I need to experiment a bit. I tried my current standard def DVDP (Denon 2910) at 1080i, I liked it better at 720p. I let the player do the progressive scanning (film mode off on tv). Colors looked a little washed-out and just didn't notice any better resolution at 1080i.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Not a gear head...but I was advised from a true gear head that the best resolution is had by matching the output of the DVD player with native resolution of your TV.
Can anyone tell me how to determine the native resolution of my Plasma?Cambridge Audio AZUR 640R
KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
Sub Outlaw LFM2
Panasonic Plasma 1080i (50u)
Sony DVP-NS70H (DVD)
Belkin Pure Audio PF31 Line Conditioner -
Great question. I just always thought to set both as high as possible. My TV supports 1080i, and DVD player can play 1080i, so that's what I've gone with since I got my first upconverting player.
My players are HD-XA1 / HD-A2 and TVs are Samsung Plasma HPR-S4252 and Westinghouse LCD LTV-32W1, respectively. Happy to accept any settings help.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
auto_pilot wrote: »Not a gear head...but I was advised from a true gear head that the best resolution is had by matching the output of the DVD player with native resolution of your TV.
If 1080i is your max output, I would imagine it's 720p native. I'm gonna try mine again tonight with the Denon set to 1080i...hmmm...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Native resolution is the native pixel count of the screen.
1920x1080 pixels in the screen 1080p native.
1280, 1024, etc.x720 pixels in the screen 720p native.
Note that 720p TVs tend to have variable counts of pixels at the higher end which forces the TV to use non square pixels and scaling internally to get the picture to display properly. Also, there is no 1080i native plasma or lcd tvs as all digital panels and projectors are progressive native. They put an interlaced signal togther internally before displaying it. -
Cheddar Cheese,
So, in your opinion, should my player(s) and TV(s) be set to 720p, or left on 1080i? Is there really a noticeble difference what they are set to?Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
If you have upconverting DVDP, run it at your TV's native resolution. This will prevent double scaling (480i to 1080i and then back to 720p).
If you have HD-DVD or BluRay, run it at their native resolution (1080i60/1080p24 for the material, some scale it to 1080p60 and output it that way). This way your TV will do the downscaling. Since most plasmas are, like cheddar mentioned, not squared pixels due to non-720p pixel count, I believe the TV will know better how to scale for its native resolution.
As always, try it out and see what happens. -
Also, I have found that there is a lot of variability in the quality of the internal scalers in HDTVs, with the general trend in putting cheap scalers in most sets. All HDTVs have to upconvert (or downconvert) non-native signals to the native progressive pixel count of the panel or projector. And they generally will do a poor job compared to more expensive and specialized chips in players. That's why upconverting dvd players are so effective. They bypass these poor internal scalers producing a much better picture. I'd lean toward not using the scaling in the TV if possible. Feed it a native signal so it doesn't have a chance to produce bad artifacts in the picture, unless you have the rare set that does a better job.
Just to confirm, you suggest setting players to 720p for those of us using upconverting / HD sources with 720p panel tvs. That way, my TV's potentially inferior scalers won't jack it up.
Got it, thanks.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Yep, I even went as far as taking my HDTV's outboard box with all the scalers, tuners, etc. out of the loop. I was lucky that my HDTV had the option with the outboard box. But the change was spectacular with my 1080p blu-rays. It only accepts a 1080p signal in this configuration, but everything, color, sharpness, contrast, black levels, were instantly improved with great detail and quality across the board. The internal scaler in my old sharp gx6u sucked...
Edit: I should add that the TV's electronics were only downscaling 1080p to a 1080i signal and then upconverting it back to the native 1080p of the panel (remember all those silly 1080p but really only 1080i TVs they used to sell?). Changing resolutions from 480p to 1080i (and back up to 1080p) in my set was horrible. My blu-ray player upscaler for dvds does a much more seamless and better job going from 480p to full 1080p. If you know of a TV that does a good job of upconverting 480 resolutions, I'd love to hear about it. But most sets I've seen look all fuzzy, jagged, and snowy. To me, that alone speaks to the poor quality of the internal scalers in most sets. -
Okay, just did some research and my Sammy plasma is 1024 by 768. Now I'm really confused. Oh well, looks good to me set to 1080i. Maybe have to visit the manual tonight.
My westy is claiming 1366 by 768.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
i would think setting it to 1080i would produce better resolution and let the TV downscale to 720p. also, most plasmas native highest resolution is 1080i, only newer model are 1080p.
I should have added that many 720p sets are also variable on the lower end pixel count as well. But any of these 720p sets will optimize their display for 720p input. It's just which scalers you think do a better job, the ones in your player or the ones in your TV. There were other things I was bypassing in my setup in addition to resolution (color processors, black level adjustments, etc.) so maybe the change for me was more dramatic than most. But it did make me very skeptical of the electronic voodoo it takes to make all the varying signals we feed our TVs these days acceptable looking at native output. I really would like all sets to have a simple bypass setting so that you can eliminate all the conversion tricks when feeding the TVs a good, high quality HD signal. I think only the more expensive modern sets have settings that allow untouched 1080p passthrough from HD players.
Cool...post your results to this thread.
I'd be interested in knowing what your results will be.Cambridge Audio AZUR 640R
Sub Outlaw LFM2
My TV is 720p native.If you have upconverting DVDP, run it at your TV's native resolution. This will prevent double scaling (480i to 1080i and then back to 720p).
I do as Sami said above with Bluray I set output at 1080i.
For standard DVDs I set output at 720p.
These are the settings that work best for me.
Try yours on the different settings and see which YOU like best.
I would not go lower than your tvs native resolution though. -
auto_pilot wrote: »Cool...post your results to this thread.
Same result as before, at 720p native the picture just looks better, richer. But, keep in mind I did not recalibrate the TV. I think the Denon does a better job at progressive scanning than the TV. Bottom line, the best combo for me is having the Denon output 720p via HDMI to the Samsung's native resolution of 720p.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Absolutely. The reason I explained in my earlier post. If you set it to anything else you scale the picture twice instead of once.
If you output 720p from your Denon this will happen:
DVD 480i -> Denon scales to 720p -> TV (no scaling) -> screen
If you however put it to 1080i this will happen:
DVD 480i -> Denon scales to 1080i -> TV scales to 720p -> screen
As the picture is first converted to look good in 1080i, which means adding and guessing new pixels, and then downscaling it to 720p which means removing extra pixels it is no wonder it will look much worse than the option #1 where you have only one scaling.
With HD it's a bit different though as they are 1080i60 (or 1080p24, but either way it doesn't require scaling, only interlacing so no pixels are added by algorithms).
HD player 1080i -> TV scales to 720p
HD player scales to 720p -> TV (no scaling) -> display
No matter which scaler is better, the one in your TV or the one in your HD player, it's not going to be that much difference as it is with double scaling (and on double scaling both scalers are used). -
that's it. everyone's mileage may vary. just try different settings. conventional wisdom/logic does not always apply.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I played around with this quite a bit when I got my Oppo and it was no contest. Letting the dvd upscale to the native resolution of the tv was much better than letting the tv do it. As mentioned before, ymmv."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Of course you forgot the obvious other one step option. DVD players output 480p -> TV scales once to 720p. So it does matter, in the end, which scaler is better. -
If it is upconverting player designed to upscale I'd probably just let it do it. If it's regular 480i player, or progressive 480p, you don't have a choice.
Either way, no matter which scaler is better, the end result is almost guaranteed to be better than letting both of them scale.
The best solution is to buy/rent HD only and output at 1080.
Well, let's just say that processing down from too much information is always better than processing up from too little...;) -
I have a 1366x768 plasma (Panasonic TH-50PH9UK). It's weird that plasma manufactures picked a resolution that is native to nothing, so everything must be scaled at least once. I've switched back and forth between 720p and 1080i and really can't tell much of a difference although I usually end up going with 1080i. I think it's the thought of the scaler making up 48 extra lines from thin air that pushes me away from 720p. In the end the picture is absolutely stunning (regardless of resolution) with a good high def signal so I'm happy anyway.
bamadudeAVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE] -
bamadude
It is curious how loose the standards were for the early flat panel televisions. You actually have one of the more common plasma resolutions for 720p HDTVs. Just be happy you don't have one of the 1024x1024 sets...:D.
