Polk C400.4 enough to power MMC6500 & db570?
aphexii
Thinking of getting the following;
Polk C400.4 Amp
MMC6500 for the front
db570 for the rear
Will the amp (which is rated at 75w/ch) be enough?
I read a review that the amp is underrated, and that it actually gets closer to 100w/ch at 13.1v and 4 ohms....
Polk C400.4 Amp
db570 for the rear
Post edited by aphexii on
Should be fine. I think the birth sheet on mine is 94w per channel. Of course you can always add an amp later if you're not satisfied.
That amp will be a perfect match. They make well over 75 watts cleanly and will power those speaker well.polkaudio sound quality competitor since 2005
I just got my C400.4 and the birthsheet tested at 95 watts per channel!
I feel like I got screwed cause my birthsheet said 89x4 on my c400.4
Well considering you only paid for 75 watts and you got 89 instead, Id say you got a pretty good deal.polkaudio sound quality competitor since 2005
