My Big Effin' Cables!!
12467
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2007
  • Early B.
    Early B. Posts: 7,900
    edited July 2007
    WilliamM2 wrote: »
    Current cables? I have Blue Jeans, Audioquest, Monster, Dayton, and Monoprice. They all sound the same.
    I would expect all of these cables (except the higher end Audioquest) to sound the same, too. What do you expect? They're cheap cables.
    "God grooves with tubes."
  • george daniel
    george daniel Posts: 12,096
    edited July 2007
    Is it raining outside? :confused:
    treitz3 Posts: 19,950
    edited July 2007
    From the Boston Audio Society..........
    The ABX Comparator
    Historically, it was an interest in tracking down the source of perceived differences in the playback chain that led to the construction (by David Clark and associates) of ABX boxes like the one Meyer was to demonstrate at this meeting. During the next portion of the evening he introduced the ABX box and played with it a bit to show how it worked. The system assembled for the meeting comprised an Apt preamp, Audio Dynamics power amp (Japanese, class AB, bipolar), the Allison 205 3-piece satellite/woofer system (lightly equalized with a dbx 10/20 to boost the low bass and help ameliorate a presence wrinkle), and an AR turntable fitted with a JH Formula Four arm and Stanton cartridge.
    The ABX comparator switches between two sources. The box has three buttons on the remote and three LEDs on the front panel, labeled A, B, and X (hence the product name). There is another pair of buttons, labeled Down and Up, which change the numeric display on the unit. When the box is powered on, it generates 100 random assignments of X to either A or B, one for each possible displayed number on a two-digit readout (00 to 99). A Reset button on the main control unit returns the sequence to test number 01. Pushing A connects source A to the output, and likewise for button B. Pushing X connects the box-selected source, which is either A or B. Neither the operator of the box nor the listeners have any notion of which source is X until the answers are read out at the end of the test. This kind of test is called double-blind, as neither the tester nor the tested knows the answers.
    I am curious as to why this test would be valid, since you are adding another circuit to the chain. If you add another component to the test, you invalidate the test as a whole. Not to mention, besides adding the ABX Comparator, they also add into the loop an EQ. That's two completely different circuits that are added before the test is even begun.
    There is no mention of Xnsfrmr isolation, shielding or how this box and EQ affect the outcome from the source before the test even started.:confused:
  • MacLeod
    edited July 2007
    The box is simply a switching box. The material doesnt play thru it, it merely switches between rigs.
    If the EQ'ing was present on both sources equally, it wouldnt make a difference.
  • PoLk FaN
    PoLk FaN Posts: 81
    edited July 2007
    WilliamM2 wrote: »
    You will not get the full benefit of the cable without one of these:
    http://www.machinadynamica.com/machina44.htm
    Read the reviews at the bottom, they hear differences too!:rolleyes:
    that was some funny ****
    HT Rig
    Receiver- Denon avr 1910
    Mains- Polk Audio Monitor 60
    Center- Polk Audio CS2 series II's
    Surrounds- Polk Audio Monitor 40 series II's
    Surround Backs Polk Audio Monitor 30
    Subs- Mirage S8 & Psw505
    T.V.- 46" Samsung lcd 120hz
    Blu-Ray- 60 GB PS3
    HD Dvd-Toshiba HD-A3
    Xbox 360- O town killer81
    tonyb Posts: 33,066
    edited July 2007
    Early B. wrote: »
    And there in lies the problem.Lots of people want to compare cables in the same price catagory,and don't get why they don't hear a difference.Boggles my mind every nay sayer will do this.Experience is the best teacher,so until you can get your ears on some good quality cables,your opinion means squat.Thats directed at William,not you Early.:)
  • madmax
    madmax Posts: 12,434
    edited July 2007
    I wouldn't call Josh a troll. That seems a little insulting. He does have a wealth of people around him to learn from. Ask Matt sometime how simple cables are... :)
    madmax
    Vinyl, the final frontier...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2007
    madmax wrote: »
    madmax
    Agreed, he can't work somewhere a have an opinion :rolleyes:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • MGPK
    MGPK Posts: 88
    edited July 2007
    I'm now a huge believer that cables do make a difference. Especially power cables and power conditioners.
    The other day I replaced the power cable on my fridge and wow, my beer has never been so cold and I think it actually tasted better than before as well. Then I hooked up a power conditioner to that cord and not only is my food fresher, I am so pumped because I never have to buy baking soda again.
    I then hooked up a new power cable to my vacuum cleaner, and I don't know what it is but that vacuum can suck an ancient virus out of the sea now. I hooked up a power conditioner to the vacuum and now I don't have to by carpet fresh now either. Those power conditioners are really a money saver.
    Then I replaced the power cable to my washer and now my whites are the whitest ever and colours don't run anymore.
    You know, I used to believe in logic and empirical data before, but how can I after those revelations. Thanks again guys for changing my attitude.
    System:
    H/K AVR430 Receiver
    Samsung DVDHD841 Dvd player
    Yamaha CDC506 5 Disc changer
    Jamo E855 Tower speakers
    Wharfdale Pacific P-10 Bookshelf speakers
    Acoustic Research Master Series Interconnects
  • snow
    snow Posts: 4,358
    edited July 2007
    MGPK wrote: »
    Great another Bozo with verbal diarrhea. If different power cords interconnects what have you dont work for you fine, But please if you have absolutley nothing to contribute here shut the FU*K up and go away.
    There may be any number of reasons why trying a different power cord or interconnect does not yield the same results for everyone. your amp may not be able to reveal the difference as well as someone elses, your hearing may not be as good as someone elses. who knows why some hear more of a difference than others? the possibilties are endless. Give it a break allready with the because it didnt work for me it wont work for anyone else attitude.:rolleyes:
    REGARDS SNOW
  • disneyjoe7
    edited July 2007
    treitz3 wrote: »
    Polkfest '04 had a test using a PC swap in a Jolida. Everybody there heard it, and the difference was not subtle. As I was saying before....bring your **** to Polkfest to where you CAN hear the difference. Otherwise, please stop interrupting conversations of folks that have a high enough resolution system to be able to recognize the differences that PC's make.
    It was that day cables made me a believer, the geek in me what'd to take it apart to see what makes that tick. The fact it was running though 14/2 to an outlet, and just that cable made such a difference it was short of amazing to all how heard it. I know a cable can make a difference and a bit sad when someone never heard the difference a cable can make...
    But on the other hand his or hers bank account may look better then ours given the fact we believers will spend $$$ finding that sound... :cool:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited July 2007
    William, if you have these cables then you might have a weak link in your system
    Ahh, "your system isn't good enough" to hear it argument. Was wondering how long before that would pop up.
    Don't you mean "see" the difference, since everyone saw the cables...
    There you go again, trying to tell me where and when I can post. Give it up already.
  • WilliamM2
    edited July 2007
    That's odd, I have read many posts here from other members claiming that Blue Jeans or Audioquest improved their sound. I guess they were imagining it.
    The cables we listened to at a dealers in a blind comparison. were much more expensive.
  • WilliamM2
    edited July 2007
    Great, another member who thinks no one is entitled to post an opinion, if it doesn't agree with their own.
    Actually, there is only one reason - Lack of imagination.
  • snow
    snow Posts: 4,358
    edited July 2007
    WilliamM2 wrote: »
    I never said he was not entiltled to his opinion did I? Everyone here is. He wasnt making an oppinion, he was doing what your doing right now running his BIG MOUTH for no good reason. If he had said I tried an expensive power cord and it didndt make any difference that I could hear that would be different, but instead he chose to make a smartass comment is all.
    If you dont agree with what I believe fine, But dont tell me that I do not hear what I do because thats plain stupid.
    Perhaps power cords do not make a difference to you fine. Im not trying to convince you otherwise.
    If I said that You should hear a difference and your wrong because you dont, then I would be doing the same thing you are wouldndt I?
    Grow up get a life.
    REGARDS SNOW
  • Gaara
    Gaara Posts: 2,415
    edited July 2007
    MGPK wrote: »
    I am not going to jump into the cable debate, but found these comments amusing because of personal experiences.
    A manger at the store I used to work at was actually so mindwashed by Monster that he would not vacuum plugging the vacuum into the wall. He always wanted it plugged into a line conditioner because he felt it worked better that way and was quieter. He actually used to show customers how it changed the vacuum, and then told them about all the benefits it would do for their HT.
    One of the reasons I quit was because I refused to sell these. Sales guys were pitching the dryer ones as they would reduce the amount of time it took to dry your clothes, dyed them better without burning them, and some even said they had surge protectors built in. There were honestly a bunch of salespeople who thought your appliances would run much better with upgraded power cords.
    Just thought you guys would like to know.
    edited July 2007
    WilliamM2, not only is your audiophile card revoked so is your ability to read and comprehend card. Please, just shut the F*%K up with your horsepucky.
    I have witnessed donkey's that have more smarts than you.
    Your **** is getting VERY old.
  • WilliamM2
    edited July 2007
    treitz,
    Why the constant need to use profanity? That is the true sign of a lack of intelligence.
    If you don't like my posts, don't respond to them. Me? I'll post what I want, no need for your permission.
    edited July 2007
    WilliamM2 wrote:
    intelligence.
    That says it all.
    edited July 2007
    I see you had to edit. You corrected in time.
  • WilliamM2
    edited July 2007
    So you've never typo'ed? How impressive.
    edited July 2007
    This is a test......This is a test of the emergency broadcast system........This is a emergency that will not be followed by a test tone.........
    So, you "Non Believers".........would you say that SACD sounds the same as redbook?
    Cd's sound the same as LP's?
    LP's sound the same as 8-track?
    8-track sounds the same as 2 dixie cups and a string?
    This concludes the test of the Emergency Broadcast System. In the event of a future emergency, apply lipstick to your ears in the hopes of attracting the sound of high fidelity.
  • snow
    snow Posts: 4,358
    edited July 2007
    Lasareath wrote: »
    Hey Early, I'm sorry I don't believe it, Have you opened up your equipment and checked out the gauge of the wire that is soldered from the IEC Chassis mount connector?
    I'd figure it's 10 gauge at the most, most likely 12 or 14. So you added 2 feet of 6 gauge wire and it sounds amazing?
    If it was that easy don't you think that the manufacturer would have 6 gauge powercords?, and maybe all of their internal wiring would be 6 gauge?
    I think it's in your head. You need to fool yourself into thinking you a hear a difference because you just spent 600 bucks on the powercord. If it cost 15 bucks do you think it would sound the same?
    Las
    I think it will make a difference allright Las. Not sure if for myself if it would be $600.00 worth though.
    I think Hearing impaired has a PS cord that he bought maybe borrow his or go over and compare cords to see if you can detect any audible change.
    Pretty much everything I have ever done audiowise has made a difference not all of it has been positive though but I certainly could tell a difference.
    REGARDS SNOW
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Anyone want my opinion?
    Ben
  • snow
    snow Posts: 4,358
    edited July 2007
    ben62670 wrote: »
    Why not? :D
  • ben62670
    edited July 2007
    snow wrote: »
    Why not? :D
    Thanks Snow. I wish I had an opinion on power cables. I am seriously considering a DIY power cable hard wired directly to my amp, and hard wiring all the caps together to bypass those silly flat steel busses that are inside my amps! I have been looking at Carol wire for the project. I think wiring directly to the innards is bet than adding 2 connectors for the IEC thing. More connectors is more problems!
    Ben
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited July 2007
    HIlarious thread. Especially Trietz's non-sequiters...
    Absolutely hilarious...
    Me, I'll side on the same side as centuries of metalurgical studies, decades of accoustic and electrial studies, and several millenia of phsychological studies versus claimed opinions of comprimised individuals. Basically, humans are flawed measuring devices and if the signal out is the same in all cases tested then they will all sound the same.
    Please notice that I did not say that they do or do not make a difference...
    Those of you who think "tone" can be transfered and produced by some other method beyond electrical signals, please seek help. If an oscilliscope can't see it, there is no way you can hear it.
    BTW, I have had my hearing checked last August and was acutally surprised to find that my hearing is better than 99% of the populations.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
    edited July 2007
    If you think everything can be measured by an electronic device, you're in the wrong hobby there guy.
  • ben62670
    edited July 2007
    jdhdiggs wrote: »
    JohnK has been reincarnated:eek:
    Sorry John:p I could not resist. To each his own. I wish I couldn't hear a difference:( It can get expensive getting nice cables.
    Ben
