New door
Willow
Willow Posts: 11,224
edited July 2007 in The Clubhouse
I'm trying to find out what it can cost to replace a hollow colonial style door (to a Bdroom)?
Any idea?
Post edited by Willow on
  • Face
    Face Posts: 14,340
    edited July 2007
    What'd you get mad at the door? :D
    If it's a home depot/lowes door, you can generally just buy a new slab which would be cheaper. Otherwise, you'll have to buy a new pre-hung and it's more labor intensive.
  • MrNightly
    MrNightly Posts: 3,370
    edited July 2007
    HD and Lowes sell colonial slabs as well... usually range from $65 to $400... depending on the finish. Go ask the Lowe's guy in doors and windows. They'll give you all the info you need.
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • Willow
    edited July 2007
    thanks, I tried looking at HD website and couldn't find anything. I'll stop by after work. I was just curious on rough prices.
  • wallstreet
    wallstreet Posts: 1,405
    edited July 2007
