New door
Willow
I'm trying to find out what it can cost to replace a hollow colonial style door (to a Bdroom)?
Any idea?
Any idea?
What'd you get mad at the door?
If it's a home depot/lowes door, you can generally just buy a new slab which would be cheaper. Otherwise, you'll have to buy a new pre-hung and it's more labor intensive."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
HD and Lowes sell colonial slabs as well... usually range from $65 to $400... depending on the finish. Go ask the Lowe's guy in doors and windows. They'll give you all the info you need.Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
thanks, I tried looking at HD website and couldn't find anything. I'll stop by after work. I was just curious on rough prices.
<$100
