Polk Audio SurroundBar (42", 50", 360 DVD Theater, SDA IHT) - Review/ Help Thread
There is no way that a SurroundBar can handle full range frequencies, so by setting the speakers to large you're going to cause damage to the speakers. You need to set them to small so that all low end frequencies are deferred to the sub........VXR8 wrote:As for the sound, I have set all speakers to "Large" and have the sub at about 100.comment comment comment comment. bitchy. -
brettw22 wrote:There is no way that a SurroundBar can handle full range frequencies, so by setting the speakers to large you're going to cause damage to the speakers. You need to set them to small so that all low end frequencies are deferred to the sub........
Hi Brettw22,
The settings are as per Polk Quick Start Guide included with the SurroundBAR. It suggests that you set all speakers to large and parallel run another set of cables to your sub input - check this link for the PDF User Guide - go to pages 6 & 7:
http://www.polkaudio.com/downloads/manuals/home/SurroundBar_QuickStartGuide.pdf
Cheers.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200 -
There is a filter in the bar so if you set the speakers to small they will be "double" filtered, in this particular case large is the correct setting per Polk HQ.
RT1 -
Interesting........that's kind of odd in that some processing is going on in the speaker based on the signal being sent through the cable.......
Carry on...........comment comment comment comment. bitchy. -
This would be great in kitchens and bedrooms where space is hard to find and you still want the sound to envelope you.engtaz
My Review...it's gonna be long.
OK, the environment:
Sources:
Mintek DVD-1600 DVD Player
Microsoft XBOX
Amplification:
Onkyo TX-SR502S 6-channel receiver
Subwoofer:
Yamaha powered sub I got from doro. I'll post the model later.
Source Material:
DVD:
Serenity -- opening scenes, opening music and a few flight and fight scenes
Firefly -- Episode One, opening battle scene, opening space scene, theme music and several dialog sections.
Days of Thunder -- many different scenes, provided a good show of surround sound.
CD:
Supertramp -- Breakfast In America (Remastered) Tracks 2 and 4
FooFighters -- The Colour and The Shape Tracks 1, 2, 4, 6 and 11
Soundgarden - Superunknown - Tracks 1, 2, 5, 8 and 12
Video Games:
Star Wars Battlefront II
Halo
First things first, hook up was a snap! It took a total of 20 minutes! Color coded and well marked, everything matched the hook ups on the back of my Onkyo. It was a no-brainer. The only way it could have taken longer is if I took the time to hide the wires and properly mount it on the wall and install the receiver and sources in a rack. I'd also have to say even though I did not use it, the wall mounting system looks stout enough and fit together perfectly with very detailed instructions! Kudos to Polk Audio for the "user friendliness"! Even my brother commented "Dude! That was EASY!"
I set the speaker up on top of the TV (27" Panasonic). Listening position was about 9 feet away. The speaker was at about chin level if I was standing up so I angled it down slightly. The room was very oddly shaped though so I wanted to give it a fighting chance. I was only pushing about 60 watts per channel to the speaker but that was more than enough juice to give it impact with or without the sub included. Needless to say though that due to the odd shape of the room, reflections suffered. It wasn't as open as it was at Polk HQ. If I had spent more time with placement, it could have improved.
Watching a movie:
The speaker did something that I see so few home theaters actually do and do well. It sounded like a movie theater. I mean, that's the point of HT, isn't it? Bring the theater home? Well, it brought it! While the surround effects did suffer due to room acoustics, the stage was still there. It wasn't as deep but there was still a good deal of sound movement all around. There was power there though. I didn't have to crank it to get the volume and physical feel you would get in a theater. Dynamics were very good too. The Onkyo HT receivers are very underrated in my opinion and the SurroundBar really showed how good the performance can be. Explosions had impact, REAL impact. You could feel it and it was very responsive. Sudden changes in volume and tone happened instantly without break-up or distortion. Dialog was crystal clear and not fatiguing at all to listen to. Music was equally as clear. Things like engines zooming in any direction didn't sound flat or tinny. I guess the best way to describe the sound was life like. I knew when there was a NASCAR stock car zooming past my head vs. a Chevy rental fleet special on a sandy beach. The rental Chevy sounds like a rental Chevy and the NASCAR stocker sounds like a race car. No coloring or dynamic compression due to a lack of frequency response. Was this the end-all, be-all of HT systems? Not by a long shot. When we listened to it at Polk HQ, it was on some decent, fairly high dollar stuff. I ran this on $450 HT receiver, one step up from entry-level/base-model. The difference? Aside from some dynamics limitations, sound was on par with what I heard at Polk HQ. It gets 4 out of 5 stars for movies. Only because even with the surround effect, multiple speakers will do better in a more difficult room arrangement. Also, the lack of displacement causes the dynamics issues and causes the speaker to get lost and lose its impact in a larger room.
Listening to music:
Dynamics. This thing does it very well with very little power. It doesn't need a sub for most stuff but if you like to listen to rock or rap or something else with a heavy beat you need one. Also, if you do alot of listening at low levels, the low-end response drops off very quickly so a sub will help reinforce that at low levels. It didn't like the loudness and bass boost buttons. Got a tad bit of farting from the speakers. The same actually went for movies now that I think about it. However, the detail was there. I'd put the sound on par with the smaller RTi speakers. The sound stage was wide just like my 2B's too. You could pick out instruments and placements fairly well. It wasn't as drastic as the 2B's can make it but it was definitely there. I would choose other speakers for music if I had a choice of an HT and a stereo rig but this speaker will do well enough for the average "Bose Rules, everybody else drools" guy. It definitely blew the Bose systems out of the water. I have several friends with Bose to compare it to and they couldn't hold a candle to the SurroundBar for music reproduction. I would again give it 4 out of 5 stars for music. The shortcomings were not enough to cause an issue for an average listener. For the "audiophile" they were worth another star off but for most people, this is way more speaker than they have ever heard in their lives. Just for that alone it gets 4 stars. It's affordable audio and a very good stepping stone to a higher level of involvement. If the SurroundBar was a gateway drug for music, it'd be one of the better ones. You can get alot out of it without alot in to it and it just makes you ache for more!
Video Games:
THIS is why I couldn't wait to get this thing in my hands to test it out! The SurroundBar absolutely SHINED doing video games! Even on a split screen, 2-player mode the surround effects and detail were awesome! The big battle scenes in Star Wars Battlegrounds had you standing in a flurry of blaster fire with bolts zooming everywhere. If you got smacked by an opponent in the back of the head, you heard the thud of the weapon on your helmet and in the proper direction. Just like when watching movies, things were zooming everywhere. Even when Luke Skywalker hacked off my head with his lightsaber I heard the lightsaber swoosh go from front to back.
In Halo, the wind was what we wanted to hear. It changes depending on where you are in the battle field. With only two players, it was easy to localize stuff and see how good the surround sound is. Movies are busy and it can be difficult to localize a sound and follow it. I imagine if I had better demo material available for the movies, it would have been better but I was more concerned about video games since I didn't get to hear that at Polk HQ.
For video games, I give it 5 out of 5 stars. It performed beyond my expectations in the surround sound effects and met my expectations in dynamics and accuracy. It added a touch of realism to the games and it honestly made Star Wars Battlefront more enjoyable than it already was. If you want a surround system for a video game system that doesn't take up a ton of room, this is it. Look no further! Buy yourself a SurroundBar, mount it on the wall or on top of the TV, get a cheap receiver and go to town! I was very impressed!
Overall rating: 4.33 stars out of 5
This isn't the ultimate HT system. It's supposed to compete with the HTiB systems and the likes of Bose. However, like most of Polk Audio's other products, it delivers the goods for a price that makes you feel like you stole it! Add a small sub for $200-$300 and pick up an entry level HT receiver from any major name and you have a very nice setup for less than $1500. This would work great in a bedroom, game room, kid's room or even a garage. It's unobtrusive and blends in to many decors with ease. That gives it a high WAF rating! It out-performs many of the small sub/sat HTiB systems already on the market and even out performs most of the HTiB systems that are more expensive. The only thing lacking is a 6th channel. Since most material is not distributed in 6 channels yet anyway, that's not a big deal. The "industry standard" Bose and their Acoustimass and Lifestyle systems do not compare. This sits head and shoulders above them in dynamics, accuracy and frequency response. This sounds like I am gushing but this speaker performed very well in near ideal conditions at Polk HQ and then in far from ideal conditions in my parent's home. It performed so well that my father was asking about price and where to get one and what he would need for it.
So yes, go and get this SurroundBar. I wish I had more time with it. It'd be good for almost any room in the house. I don't think it would fair well in a kitchen or a bathroom though. Anywhere else, it's a winner for sure!Expert Moron Extraordinaire
Great review - I'll try the XBox games too, as I haven't tried the SurroundBAR with a games console yet. Happy with both 2 channel and DVD as well.
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
shipped the SurroundBar to the next person to demo it..
here is my review.
First off, the SurroundBar is heavy. Much more heft to it than I thought it would be. Heavy is good. I hoisted it up on top of my 32" tube TV and it sat there like it was made for that TV. Nice.
Since my TV is on a higher TV stand... I had to point the SurroundBar slightly downward. No problem.. the stand is secure and made it easy to aim it down or upward as needed.
Wiring is so simple.. all color coded wires... so unless you're color blind, you should have no problem at all wiring it up.
movie's. I used my fave movie that I enjoy where I know has a good surround channel in the rear. I used Black Hawk Down. Half way thru the movie I noticed that the surround channels were really lacking any ooph.. so I cranked the rear left and right channels to max.. +12. that helped quite a bit. Once I did that.. the movie really came to life and while the rear channels weren't behind me sound wise. I could hear the rear channels extend out beyond the SurroundBar itself to the left and right. Making the soundstage much wider now.
music. I have to say in my demo, the SurroundBar can't really do music well. The lack of full range front speakers really killed the live feel to any music. Even with my big **** subwoofer.. the fronts still sounded way to tinny for it to be listenable. So i did less music listening than movie watching.
Bottom line.. for those folks who don't want to wire up their house for movie watching.. it does ok for surround effects. First movie I watched it sounded to tinny. but I got used to that and it blended well with my subwoofer.
If you are used to having 5.1 or more speakers in your house and you want to try to recreate that enviroment in another room.. well, this may not quite live up to your expectations.
If you have a flat screen display and you want clutter free sound.. and have a decent subwoofer.. then this would probably satisfy your needs for a while.
Given the two weeks I had with it..I feel that it was enough time to do a fair demo with my set up. My set up is . Outlaw Audio 990 pre amp. 3 Marantz mono block amps for LCR and Adcom GFA 5400 for the surround channels. Each little speaker was getting it's own amp for the most part.. so power wasn't a problem in my case.
Taking everything into consideration.. my best score for the SurroundBar would have to be a 3 out of 5 for performance. 5 out of 5 for ease of use and build quality. Overall score equals a solid 4PolkFest 2012, who's going>?
I purchased the SB today after much debate regarding my current setup. For the last four years, I have had a 5.1 setup with wires running along baseboards in plastic channels. The speakers in front (Monitor30) and the speakers in back (RM101) were all on stands and presented a very cluttered environment. Now, we are in the process of painting and fixing up the TV room and the decision to remove the 5.1 in favor of trying the SB has been made. I have a few questions:
1. I have a Yamaha RX-V2500. There appears to be some debate in this thread as to how to connect the SB to the amplifier and what settings to use. Should I set the speakers to "Large" or "Small"? What should I do with my powered Yamaha sub (it has a single input)?
2. Should I use the cable provided with the SB or use a higher quality cable like the MonsterXP I already have?
3. Has anyone gone from 5.1 to SB and felt it was a comparable experience?
My room is 12'W, 17' 7" deep, with 9' ceilings. The TV is in front of a half wall facing towards the living room. -
run the surrounBar set to small fronts. and use your Yamaha powered sub.. the SurroundBar needs a good sub to really make it happy. so you may want to upgrade your sub if it's not kicking it for you.PolkFest 2012, who's going>?
danger boy wrote: »run the surrounBar set to small fronts. and use your Yamaha powered sub.. the SurroundBar needs a good sub to really make it happy. so you may want to upgrade your sub if it's not kicking it for you.
I thought setting it to "small" would cause double filtering of the bass since the SB has a filter? My receiver can be set to output base to the sub only, none, or both. I was thinking about outputing to both with the SB set to "large" and with the sub crossover at 100-120. -
That's correct, you will double filter - read your user guide and it tells you to set all speakers to large - I have one and have it set as per Polk's instructions
Main System
Denon - AVC-4700H
Emotiva - XPA-9
SVS - PB1000 x 2
Foxtel - iQ4
Sony K77A9G
Front Room System
I have a single sub-woofer out on my receiver. I will have to use it. So, using their alternative solution, I will set my speakers to "Large" and set the subwoofer to "Both". That way the bass will get sent to the Soundbar and properly filtered and blended with the Bass of the subwoofer. -
With a fairly recent receiver such as the Yamaha, if you use the "sub out" to "LFE" input on the Yamaha sub, simply run all the speaker wires directly from the receiver to the SurroundBar's respective inputs. Then on the receiver's setup menu set everything to "small", crossover = 120 Hz and subwoofer = "yes".2. Should I use the cable provided with the SB or use a higher quality cable like the MonsterXP I already have?
That is certainly up to you, however keep in mind that the Surroundbar's included cable will fit behind the speaker unobtrusively when wall mounting. If you use "aftermarket" wire, it will be considerably thicker and harder to hide.-Eric
-Polk Audio -
Thanks Eric. I will get to try this this weekend and hope to have some feedback by Sunday. -
I just got an Onkyo 605 and the speaker setup doesn't have the option to set to small or large...only set in Hz. Any idea how to equate small to Hz? -
Always run the SurroundBar set to LARGE on all five channels. (as mentioned several times in this thread) It has it's own built in bandpass filter on the midwoofs.
beaglemg - set it to the lowest Hz setting your Onkyo will allow.
Cheers,
Cheers,
Russ
This still doesn't make any sense?
Why is there a filter in the surroundbar? That's what settings in your receiver is for, correct?
This built-in filter can arise some issues for some running subs with this. As I recall, some receivers will not send LFE to the sub when in the LARGE setting in the AVR, some receivers do have a "plus" setting that will allow this workaround.
Why not make things simple like usually every other speaker for HT, set to "small / 80hz"? -
It is simple. It keeps Joe consumer from blowing up his SurroundBar. Lots of micro-sized speaker systems have built in filtering, most just aren't aware of it.
I'm not saying it doesn't exist, but I'm not aware of any modern receiver (in the past 10 years) that won't send LFE to the sub with mains set to large.
Cheers,
Cheers,
Russ
I guess, but that goes with anything really. "Joe consumer" could blow anything up if he doesn't know what he is doing.
As I recall, most receivers will NOT properly send the .1 channel to the sub if set to "large" in the AVR. One that comes up off the top of my head is my Pioneer AVR, unless I have the "plus" setting running. -
Cheers,
Russ
my speaker config options are as follows:
Subwoofer: y or n
Front, Center, Surround, etc : Full Band or 40 - 200hz
LPF of LFE: 80 - 120 hz
Double Bass: on or off
If the subwoofer is set to NO, then the receiver greys out the option to tweak the fronts.
Your help is much appreciated. My sub is a Polk 404. -
Sub = Y
Front, Center, Surround : Full Band
LFE: play with the setting, see what blends the best with the Surround Bar - 80-90Hz would probably be a good starting point.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
you'll want the most bass out of your subwoofer while using the SurroundBar, that's why i recommend using your fronts set to small. I just demoed the SurroundBar in my house three weeks ago... i know what sounded best.
the SurroundBar has seven 3 1/2" midrange driver and three 3/4" tweeters.. trust me. there is no bass coming out of that SurroundBar. that's why you'd want to run your fronts on small.
but I'd say, a person really should try both and see which sounds better for them.
for those that don't have a small or large setting in their AVR's.
large would be 40 to 90Hz and small would be 140-200Hz as crossover settings.PolkFest 2012, who's going>?
So what would 91 to 139 be?
Al, the Sbar has it's own filtering built in..... How else, or many other times can we say it?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
The representative from Polk recommended setting my speakers to small, 120 crossover, and subwoofer 'On'. Why should I question this?
you shouldn't question it... it's what i've been saying all along.. but no one listens to me..
Lets see.... you can say it in Swahili or pig latin. :rolleyes:
numbers 91 to 139 are only to be used if you have Bose speakers.
Russ, you big knucklehead, how could you ever question my authority?
OK newbie here.
My HT room has the primary viewing sofa jammed into the corner (not my choice!). As a result, there is no place to put the rear surrounds. So I am heavily considering this baby. Question though...I have about 3+ feet behind the sofa to the corner. Can I put a single speaker back there to make a 6.1 (My Denon 1804 will support that)? Will it help with the imaging? Its a Mirage AVS200 (?)...is there a better speaker (less directional??) that would work better?
Thanks! -
Ross - I believe you're from Audioholics
I'll answer here for this question but finish up over there on your earlier query if that's ok.
Yes, a single speaker would be fine but I would suggest an omni-directional speaker from Mirage(Omnisat for example, since you mentioned the brand) or even better would be a single bipole/dipole speaker from the current Polk Audio lineup(FXi30/FXi3). The problem with either choice is that you will most likely have to buy a pair.
I would try an "fill" that 3ft+ area with sound as opposed to localize it with a traditional loudspeaker. However, you can do all kinds of "odd" things with a single traditional speaker like position it on the floor firing up, ceiling firing down, etc so in the end I would suggest you play around with what you own now, and try a couple things, then break out the wallet
Does that help you?
MarkCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
