2008 LancerGTS Custom Audio Install help
LancerGTS24
Hey everyone,
I plan on doing a sick install on my new Mitsub Lancer GTS and I have a couple of questions. I have the Navigation system that has the Musicserver, etc. and I want to add two sets of Components and two 10's. I'm thinking about getting the RF 3.Sixty so that I can keep my stock HU. Does anyone have any experience or take on this DSP? Any other that you would recommend? This is what i'm thinking of so far:
-RF 3.Sixty DSP
-Polk MOMO C400.4
-Polk MOMO C500.1 (x2)
-Polk MOMO MMC6500 6 1/2 Components (x2)
-Polk MOMO 10" (x2) or JL 10w7 (x2)
Full Fiberglass trunk install w/ false floor and false back. Fiberglass for the components also in each of the doors.
Comments and suggestions are greatly appreciated.
Thanks.
Ram
-RF 3.Sixty DSP
-Polk MOMO C400.4
Thanks.
Ram
Post edited by LancerGTS24 on
i think the rf 3.sixty is mainly geared toward a stock system. i am not sure about how amps would integrate into that equation, but sounds like a killer system, regardless. perhaps mac or cory could give more info about the 3.60At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
That setup sounds very nice. I'm not sure about the 3sixty myself. However, If you have the room, I'd get 2 12" DVC momo's instead of the 10". Then wire them for a 2 ohm load each to the c500.1 and you've got yourself some amazing subs!
I'm sure the 10" momo's will sound good with 350 watts also. Just thought I'd give you my $0.02. The 12" are only a bit more expensive. -
Thats exactly what a 360 is designed for. Sounds like a killer system. I wouldnt go with w7s though, they only come in dual 1.5s which would not be a good match to those polk amps.
The 13w7 is the only one with dual 1.5ohm coils, the rest of the w7 line has single 3ohm coils.Team Schil Acoustics
05 MECA world champion
06 MECA world champion
06 MECA Culbertson cup (best of show) -
Oops, I thought I read 13w7, youre correct.
