Samsung 50" Plasma picture is off-center... HELP
StopherJJ1980
Hey polkies, haven't posted here in forever but I have always gotten great advice from these forums so maybe you can help me out. I just bought a Samsung HPT5054 50" plasma and I love it, the picture is great. It has DVD and HDTV running through my Yamaha reciever with component cables. I just had a question about my picture being off center. Basically with anything in widescreen you can't even notice, but when an HD channel or other channel/source has black bars on the side I have anywhere from a centimeter to an inch extra of space on my left side as opposed to my right side. So my alignment seems to be about a half inch to an inch off center to the right.
I called Samsung to see if I can adjust this and they said no. I exchanged the TV for the same model and got the same result. It get the same result with all sources, DVD, HDTV, PS2. Could this be adjusted? Is it a flaw? Does it have anything to do with the 'pixel shift' being on to reduce burn-in. Could it be something my reciever is doing to the video signal? (Coinicidentally my last CRT TV seemed to cut off images slightly on the right side.)
It is a minor detail, but me being a perfectionist I drive myself crazy if I sit there and watch and focus on it. But if it within the range of normal then I can live with it considering I got the TV at a pretty reasonable price. Has anyone else experienced this? Any input from you guys would be much appreciated.
-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Yamaha HTR-5740 AVR
Post edited by StopherJJ1980 on
Stopher, I never have a Samsung, so can't really help you with a direct experience. However, I had my RPTV ISF Calibrated recently. The folks who did it was David Abrams of www.avical.com
They've done many Samsung plasmas, and others. Give Dave a call and perhaps he can assist you over the phone. His business partner, Eliab, specializes in Samsung. Check his threads over at avsforum.com and might get your answer from him. hope it helps.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
My 50" Samsung plasma dose the same thing but its when I use the zoom 1 function but mine leaves a 1" black strip at the bottom of the panel. So I called Smasung last week and they was supposed to send out a tech guy.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
