Fairlady Z Is In The Shop Awaiting Stereo Installation
Tim B.
Tim B. Posts: 105
edited July 2007 in Car Audio & Electronics
I appreciate all the help and input. I have finally taking the plunge and may disappoint some of you guys but had to do it.
The 300ZX TT project final install set-up is as follows.
Head Unit: Eclipse CD7100
Components: Hertz Millie MLK 2
Subwoofer: Hertz Millie ML3000
Amplifier: Audison LRx 5.1K
This amp is amazing the specs are:
60W x 2 (4Ω) + 140W x 2 (4Ω) + 750 (4Ω)
50W x 2 (4Ω) + 160W x 2 (4Ω) + 1150 (2Ω)
50W x 2 (4Ω) + 250W x 2 (2Ω) + 1030 (2Ω)
This allows me to save a lot of space by using one amp instead of two or three of my art series amps. So now I can keep the system installed in my truck.
But don't be too mad I will be putting a set of SR's in to replace the front stage of my truck. It is set up as a 3-way system now if I can fit the 5.25s in the kick panels I will keep it that way if not might change it to a 2-way set up.
I will post some pictures when completed.
If anyone has any EQ opinions please advice. The one in the CD7100 may not be enough.
Thanks,
Tim
Car Audio System:
Front Stage: Hertz Millie MLK 2
Sub: Hertz Millie ML3000
Battery: Kinetik KHC 1400 Power Cell
Home Theater System:
Panasonic TH-42PX50U Plasma HD TV
Denon AVR-3805 7.1 Recevier
Denon DVD 1910
Yamaha DVD-C750
X-Box: Moded with 300 Gig Hard Drive
Paradigm PS-1000 Subwoofer
Bay Audio Studio Monitors: Fronts - CubeXL, Center - Cube, Side & Rear Surrounds - Mini Cubes (http://www.bayaudio.com/cubexl.html)
Post edited by Tim B. on
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2007
    It depends on how much you want to spend.
    If you can afford $800, there is no better EQ than the Alpine H701
  • Tim B.
    Tim B. Posts: 105
    edited July 2007
    Is there a straight EQ solution. I will already have two sets of x-overs in the radio and the amp. The Audison x-overs I heard are real good.
    Car Audio System:
    Denon DVD 1910
    Yamaha DVD-C750
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2007
    Nice setup Tim.....I remember we talked a little while back. To start off, the CD7100 will give you 11 PEQ bands. If that is not enough Arc has a nice stereo unit.
    Arc Audio MEQ-30
    http://www.arcaudio.com/arc-05/processors/meq.htm
    My only concern with the H700 is not having a digital connection to it. I've read several threads where people complained of a high noise floor when not using the optical connection. Mac could probably comment a little more on this.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited July 2007
    If youre able to keep your gains down, using RCAs to the input of the H701 is usually not a problem. Theres been a couple of people that I know of that still had problems, but most of the time, as long as your gains are about a quarter or less, you wont have a problem.
    -Cody
  • 1996blackmax
    edited July 2007
    That was one of the things mentioned, but some people even when the gains were properly adjusted still had issues.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 1996blackmax
    edited July 2007
    Might be worth a shot....if it does not work out well you could always return it.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Tim B.
    Tim B. Posts: 105
    edited July 2007
    I will wait to see how the eclipse works out. I kind of want to try and minimize the amout of componets used if possible.
    I would have gotten the Clarion DRZ9255, but wanted to have sat radio. Eclipse will be coming up with the XM module soon so I will wait till then. XM has better Jazz stations.
    I have looked up the MEQ-30 looks like a nice piece. How does it compare to the audio control PEQ?
    Car Audio System:
    Denon DVD 1910
    Yamaha DVD-C750
  • 1996blackmax
    edited July 2007
    I think both companies make nice units....with the Audio Control units you will probably get more flexibility as some have more than just 2 inputs/outputs.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • killerb
    killerb Posts: 390
    edited July 2007
    http://mobileaudiocontrol.com/product.asp?Product_Id=19173&d_Id=5247&l1=5247&l2=
    this should fit the bill for the e.q., its hard to beat audiocontrol's quality.
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • Tim B.
    Tim B. Posts: 105
    edited July 2007
    That is the unit that I am considering. If it does not work like I am expecting that would be my next purchase. I may even be willing to trade an amp for one.
    Car Audio System:
    Denon DVD 1910
    Yamaha DVD-C750
