a/d/s 10'' subwoofer on the wootoff
seeclear
"""It Stands For A-Expensive D-Expensive S-Expensive
OK, look. Even elite speakers get desperate every once in a while. Under normal circumstances, the a/d/s HT10PS 10 Powered Single Reflex Subwoofer wouldnt lower itself to be seen with you. You think it likes the idea of you drooling all over its double-stacked 50 oz. magnets? You think its stomach doesnt turn at the thought of your filthy hands on its long-excursion 10 paper cone? Do you really think it would enjoy putting its smooth, pristine 300-watt signal in your waxy ears?
Of course not. This is a subwoofer from one of audiodoms finest families. But it got mixed up in some nasty stuff, and wound up owing a lot of people a lot of money, and its on the run from its old boyfriend In short, its desperate. And thats why a shlub like you has a shot at the a/d/s HT10PS 10 Powered Single Reflex Subwoofer. Act quick, small-fry. A speaker like this might never look your way again.
Warranty: 90 days Woot
Features
Long excursion 10 paper cone with double stacked 50 oz. Magnets
RMS (Continuous) Power: 300 watts RMS
Frequency Response: 20 200Hz, 1 dB
Total Harmonic Distortion (THD): <0.08% THD
Sound Pressure Level (SPL): 113dB @ 1 meter
Technical Details
Model: HT10ps
Item Package Quantity: 1
Maximum output power: 300 Watts
Depth: 16.4 inches
Height: 18 inches
Width: 19.25 inches""""
FWIW, this is the blurb for the sub on the wootoff, did not know if anyone would have any interest....
Features
Technical Details
Model: HT10ps
Depth: 16.4 inches
Height: 18 inches
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
A/D/S does make some awesome audio gear. 113db from a 10 powered by 300 watts is quite impressive, and flat to boot!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
