a/d/s 10'' subwoofer on the wootoff
seeclear
seeclear Posts: 1,243
"""It Stands For “A-Expensive D-Expensive S-Expensive”
OK, look. Even elite speakers get desperate every once in a while. Under normal circumstances, the a/d/s HT10PS 10” Powered Single Reflex Subwoofer wouldn’t lower itself to be seen with you. You think it likes the idea of you drooling all over its double-stacked 50 oz. magnets? You think its stomach doesn’t turn at the thought of your filthy hands on its long-excursion 10” paper cone? Do you really think it would enjoy putting its smooth, pristine 300-watt signal in your waxy ears?
Of course not. This is a subwoofer from one of audiodom’s finest families. But it got mixed up in some nasty stuff, and wound up owing a lot of people a lot of money, and it’s on the run from its old boyfriend…In short, it’s desperate. And that’s why a shlub like you has a shot at the a/d/s HT10PS 10” Powered Single Reflex Subwoofer. Act quick, small-fry. A speaker like this might never look your way again.
Warranty: 90 days Woot
Features
Long excursion 10” paper cone with double stacked 50 oz. Magnets
RMS (Continuous) Power: 300 watts RMS
Frequency Response: 20 – 200Hz, 1 dB
Total Harmonic Distortion (THD): <0.08% THD
Sound Pressure Level (SPL): 113dB @ 1 meter
Technical Details
Model: HT10ps
Item Package Quantity: 1
Maximum output power: 300 Watts
Depth: 16.4 inches
Height: 18 inches
Width: 19.25 inches""""
FWIW, this is the blurb for the sub on the wootoff, did not know if anyone would have any interest....
:D:D:D:D:D:D:D:D:D:D:D:D:D
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    A/D/S does make some awesome audio gear. 113db from a 10 powered by 300 watts is quite impressive, and flat to boot!
    Ben
