Best Path For Computer to Receiver?
smalltownheel
Was wondering if I should use AirExpress w/ AirTunes from apple to get my music from iTunes to my Denon 2803 or just run cable underneath the house? I read that through AirExpress you lose sound quality, but I could buy the remote to go with to have more control. If I go underneath (less than 20 ft. run) what cables should I use? Thanks.
Post edited by smalltownheel on
connecting a computer directly to a avr almost everytime has a ground loop problem. Unless both are on the same circuit.
Depending on your outs on your computer, using coax for long runs is perferred. Or even rg59sd. Then terminate with RCA ends.
You may need a gound loop buster.
I perfer to use Sonos for computer to gear transfer.
www.sonos.com
DanDan
Mine are on different circuits and no ground-loop problem.
My mobo(ASUS A8N32-SLI Deluxe) has optical, coax, and analog outs. I'm using Monoprice coax from the mobo to my Onkyo receiver and a SignalCable Silver Mini from the mobo to my McIntosh Pre."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
My PC is connected to a SilverStone EB01 USB DAC (internal soundcard was noisy and poor sound quality) and via a Belken PureAV RCA audio cable, 12 feet to my stereo receiver with no ground loop problems even though they are on the same circuit.
I also stream via CAT5 over 50 feet to my Roku Soundbridge (wireless constantly rebuffered WMA lossless) and then digital coax into my Onkyo 603 AVR, again with no problems -
I use an M-Audio Sonica USB device to send a digital signal to whatever source or system I want.
I suggest using some sort of device that will send a digital signal Vs. analogue. -
Thanks for all the help! I've read about sonos and it seems really nice, but not really trying to spend that kind of money. Maybe in the future though. Got to get back to work so I'll figure it out and post what I decided later. Thanks again, this is truly a great place! Now if only I can get some replies to my thread in the Speaker Forum.:)
Is this what you recommend phuz? http://www.amazon.com/ M-Audio-Sonica-Theater-24-Bit-Surround/dp/B00009L7N9
Nevermind, link didn't work, 1st time trying to insert a link.
Tried to link this -->M-Audio Sonica Theater USB 24-Bit Surround Sound Module
I'll try again, MLZ??? -->http://www.onheadphones.com/product-reviews/dac/silverstone-ensemble-eb01.html + http://tech.yahoo.com/pr/ belkin-pureav-rca-audio-cable-12-ft-/1991386422
I guess links work now??? -
I guess I'm an idiot b/c the more I read the more confused I'm getting. Guess I just need someone, in as dumbed down a way as possible, tell me what exactly to buy. Not looking to spend over $175, if thats possible.
smalltownheel wrote: »Is this what you recommend phuz? http://www.amazon.com/ M-Audio-Sonica-Theater-24-Bit-Surround/dp/B00009L7N9
That is what I have and last year the best price was from NewEgg http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=EB01&x=16&y=27 The silver version is cheaper now because it is not in stock . I paid ~$85.00 last year for the silver because then the black was not in stock.
Note the EB01 is only 2-channel (all I wanted or needed) while the MAudio is 7.1
While Monoprice.com might be cheaper for the analog cables between the DAC and receiver, I just purchased mine from NewEgg while I was entering my order.
Anyway I am very happy with the sound quality and the convience of having all my CD's (over 650) ripped to a lossless format and played via Windows Media Player 11 -
The price on this isn't bad if you don't mind running a cable. http://signalcable.com/analogmini.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I don't mind running a cable at all. Just want to know the best way at a reasonable price. The cable suggested is an analog cable and I think it was phuz who recommended that I only run a digital??? I would also like to have the ability of 5.1, but since its for music, I guess 2-channel will do. Do ya'll usually listen to music on 5.1 or 2-channel? My setup: Denon AVR-2803, LSi15s, LSiC, LSiFX, and SVS PB12-Plus
Squeezebox! I love it. Simple. Easy. I have it connected to a switch (shared with an Xbox 360 and a Buffalo Link Theater). Will integrate with your iTunes. Unfortunately, it's a bit outside your price range at $300.
http://www.slimdevices.com/
Another option is a Buffalo Link Theater on clearance from frys.com for $89.99 with free shipping. http://shop4.outpost.com/product/4441996?site=sr:SEARCH:MAIN_RSLT_PG
The Buffalo, regardless of the advertisement on the box, will not play Apple Lossless which is why I have a Squeezebox since all my stuff is in wave or apple lossless (we have a few ipods in the house).
If you can, I highly recommend the Squeezebox. -
1. can you guys explain this ground loop issue. I had been running my computer out to my receiver with the single strand line that connects to a y adaptor at the receiver? Nothing in between. Now that I have a longer run, I get a lot of hum, especially whenever the plug touches anything metal.
2. For wirelss options that use 2.8 gHz broadcasting, does this knock your wireless Internet router off?
Thanks -
For over a year now i have my computer with a basic sound blaster card with rca outs. Bought a $12 20 foot rca cable running into my Onkyo. I use iTunes music and radio. Not a single problem and it sounds amazing.
NeilGabriel wrote: »1. can you guys explain this ground loop issue. I had been running my computer out to my receiver with the single strand line that connects to a y adaptor at the receiver? Nothing in between. Now that I have a longer run, I get a lot of hum, especially whenever the plug touches anything metal.
Search this forum or AVSForum or Google "Ground Loop" to understand the 60hz hum it causes.
Wireless I mentioned is 802.11 wireless networking between your router and device (Soundbridge, Squeezebox, etc.) and so shares the same internet connection for internet radio, etc. -
Yes that is what I am using. I prefer digital so that I can use an external DAC which provides better sound quality over most PC sound cards. It also prevents ground loop or quality issues that some analogue connections have. It also allows for easy surround sound from a PC. Running 5+ RCAs for surround sound would be a pain.
It wouldn't hurt to try a splitter and long RCA. If you are happy with it then go for it. -
i didnt read all of the posts in this thread, but the best recommendation i can give to you is to get a decent soundcard. i am sorry, but onboard audio is not IME even *close* in SQ to even an inexpensive card like the m-audio 2496 (about $100). FWIW.
agear list:
1 down, 4 up.... -
I use a SB XF-i that has an AC3 port to connect to my Onkio.Testing
Testing
Testing -
Hey I really appreciate all the help! I think I'm gonna go with the M-Audio. Might be a week before I get it hooked up, preoccupied with work, but soon as I do I'll let you know how it sounds.
honda cber wrote: »i didnt read all of the posts in this thread, but the best recommendation i can give to you is to get a decent soundcard. i am sorry, but onboard audio is not IME even *close* in SQ to even an inexpensive card like the m-audio 2496 (about $100). FWIW.
a
From ASUS,
"High Definition Audio
Enjoy high-end sound system on your PC! The onboard 8-channel HD audio (High Definition Audio, previously codenamed Azalia) CODEC enables high-quality 192KHz/24-bit audio output, jack-sensing feature and retasking functions. With the 8-channel audio ports and S/PDIF out interface, you can connect your computer to home theater decoders to produce crystal-clear digital audio.""He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
smalltownheel wrote: »Hey I really appreciate all the help! I think I'm gonna go with the M-Audio. Might be a week before I get it hooked up, preoccupied with work, but soon as I do I'll let you know how it sounds.
I started with an internal MAudio Revolution and a second hard drive for music files. But on my inexpensive HP the soundcard picked a lot of noise with I/O to the second drive. I also had a bit of trouble locating a free IRQ. MAudio support said if I reloaded windows with some different settings my problems should go away, but being a chicken, I returned the card for the USB DAC. The install was very quick: just pluged in provided USB cable, Windows XP SP2 figured out drivers, etc. -
I would say most onboard sound cards are junk, not all.
From ASUS,
you are absolutely right, though, that all chipsets are NOT created equally. sound, video, etc, etc. personally, i have yet to experience awesome onboard audio, even on "awesome" machines.
agear list:
1 down, 4 up.... -
anonymouse wrote: »Get a Roku Soundbridge. Worked great for me till I decided mp3 wasnt good enough. The Roku's have digital output so you can use the receiver's DAC. You can also use the analog RCA's.
Where my 2-channel system and PC were in the same room, I used an external USB DAC and play music via Windows Media Player 11.
For my living room, I used my wired network connection to a Roku Sound Bridge 1001 and then digital out to my HT receiver.
I also bought a 60 gb Toshiba GigaBeat to carry my music with me.
The cool thing is once you have all your CDs ripped to your hard drive, you can access the music files many ways. You can also back up the music files and store them offsite in case of a disaster. And at today's cost of hard drives, you should rip to a lossless format which will give you flexability as standards evolve.
