Purchasing install materials
Pantocrator
Pantocrator Posts: 84
edited July 2007 in Car Audio & Electronics
Hi again. I'll always post myy set up first- Polk SR6500's, one pair; one Polk SR124DVC, one 880 PRS, and one Memphis belle 16MCH1300.
I am buying install equipment- have it all picked out, wanted to run the list by you. I was considering either stinger or streetwire (something like that) for the wiring, decided on stinger. Please tell me if I'm getting ripped off, or if you have suggestions.
Stinger HPM Twisted SWX12BLU Speaker Wire
Part Number: STISWX12BLU1
This item is normally shipped in 4-5 days.
Remove
$0.95 $4.75
Scosche SL1-50 Wiring Loom Tubing
Part Number: SCOSL150
This item is normally shipped in 1 day.
Remove
$0.33
Free shipping! $1.65
Polk Audio MOMO Series G12 Subwoofer Grille
Part Number: POLG12
Remove
$19.95
Free shipping! $19.95
Scosche SL12-150 Wiring Loom Tubing
Part Number: SCOSL12150
Remove
$0.33
Free shipping! $2.64
Stinger Helix Series SHX420 Interconnect Signal Cable
Part Number: STISHX420
Remove
$45.95
Free shipping! $45.95
Stinger Helix Series SHX20 Interconnect Signal Cable
Part Number: STISHX20
Remove
$28.95
Free shipping! $28.95
Stinger HPM Twisted SWX16BLU Speaker Wire
Part Number: STISWX16BLU2
Remove
$0.65 $52.00
Stinger Custom Pro SWK4 Amplifier Wiring Kit
Part Number: STISWK4
Remove
$61.95
Free shipping! $61.95
Scosche DCAXPIO11 Auxiliary Input Adapter
Part Number: SCODCAXPIO11
Remove
$14.95 $14.95
Part Number
In Stock Description Qty. Price Ext. Price
260-311 Yes Gold High Power Terminal Round ..
$3.40 $3.40
260-765 Yes Cabinet Carpet Charcoal Yard 54" Wide ..
$4.25 $4.25
Subtotal: $7.65
That should cover everything except sound dampening. What are your thoughts on that subject? It is expensive, so only the trunk? Skip it all together?
My system (thanks to everybody for the help)
One pair Polk SR6500 comps
One Polk SR124DVC sub
One Pioeer Premier 880PRS HU
One Memphis belle 16MCH1300 amp
Post edited by Pantocrator on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2007
    I never understood why people drop a good amount of money on good audio components and then skimp out on the sound deadening. Might as well get lower end gear and save some coin, as you wont really get the most out of the gear purchased.
    I believe the sound deadener is as much part of a good install as the wiring and other components.
    Second Skin is top notch and reasonably priced.
    http://www.secondskinaudio.com/
    http://www.secondskinaudio.com/store.php?category=54
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Pantocrator
    edited July 2007
    Thanks for the reply- how much do I need? Like I said, I am thinking of only doing the trunk for price and ease of install... I assume the cable etc is up to standard?
  • 1996blackmax
    edited July 2007
    No problem :). Yeah, cable is fine.
    I used more than 40 square feet in my trunk, probably closer to 50. I think I used close to 30 or more for my front doors (both skins). Doing the doors will offer a noticeable improvement in the mid driver's midbass reponse.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited July 2007
    Go around all speakers, where the hole is cut a pie shape and fold it behind for more support behind the door, i do 2 layers and it sounds legit, for the trunk, just listen to it, put the mat where u hear rattles.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Greg Peters
    Greg Peters Posts: 605
    edited July 2007
    I was going to try a Momo 12" grill for my SR124, was told by the Polk dealer that it doesn't work on that sub...
  • [Deleted User]
    [Deleted User] Posts: 763
    edited July 2007
    No, it does not. Try calling our customer service dept. and see if you can buy a grill from the db-212 as a separate part. Those grills fit the SR.
  • exalted512
    exalted512 Posts: 10,734
    edited July 2007
    www.knukonceptz.com for wiring and such. Theyre cheaper and have absolutely fantastic quality.
    -Cody
  • Pantocrator
    edited July 2007
    Please tell me you're kidding. I thought that any 12" grille would fit any 12" sub- especially since they are from the same manufacturer.... the DB grills work you are sure? I forget if I already bought this... I hope I didn't.
  • Pantocrator
    edited July 2007
    Cany anybody confirm the problem with the sub grill? While we're at it, is there another speaker grill (such as momo grill) that can be used with the SR6500 that looks better than the included grill?
  • 1996blackmax
    edited July 2007
    Post #7
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Greg Peters
    edited July 2007
    Wouldn't kid about a thing like that. As per Josh, a db 212-2 grill looks promising. Check out the look- if it's what you're after, db675/6750 grills will match and I believe they fit the SR6500s...I believe they're discontinued, so hit up customer service sooner rather than later.
  • exalted512
    edited July 2007
    Considering hes an installer for Polk, I'd say thats all the confirmation youd need for the sub grill.
    -Cody
  • 1996blackmax
    edited July 2007
    Totally agree....
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • [Deleted User]
    edited July 2007
    Yes, the db 6750 grill will work for the mids, IF you are using them in component mode and not coaxial mode. In coaxial mode the tweeter sticks out too far and hits the grill. The 6750 is discontinued but we should still have parts. And, yes, confirm on the sub grill. The MOMO spokes aren't arched as high as the db grill. Therefore, the surround hits. Call Helen at 800-377-7655 x. 324 for parts.
  • black magic
    black magic Posts: 669
    edited July 2007
    I'd personally go without sub the grill. For each his own I guess.
