Wiring for outdoor speakers
crest9000
Getting ready to wire for two outdoor speakers - atrium 45s. Is there a suggested gauge of speaker wire I should use - 12, 14, 16? Running about 50-60' of cable.
Post edited by crest9000 on
Under 80 ft, 16 gauge will work fine. If you're going to run an in wall volume control, I'd upgrade to 14 gauge since the VC adds a lot of resistance.
