Speaker wire, which side is positive/negative?
impronto
impronto Posts: 25
i have speaker wire with one side with a stripe, the other not. which side is the standard for negative or positive? Thanks
Post edited by impronto on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2007
    It doesn't matter, just wire all your speakers the same.
  • duksbak
    duksbak Posts: 134
    edited July 2007
    The trick is to always be consistant.
    I always use the stripe side as my positive.
    But as russ said, doesn't matter what you use for + or - as long as you are always consistant.
    Television: Mitsubishi WD-57732
    Front R/L: Polkaudio RTiA7
    Center: Polkaudio CSiA4
    Rear R/L: Polkaudio FXiA4
    Subwoofer: Polkaudio DSW600
    A/V Reciever: Denon 2808
    DVD/SACD: Sony Playstation 3
  • tcrossma
    tcrossma Posts: 1,301
    edited July 2007
    What they said. I always hook up the white stripe, or the side with lettering or other marking, to the red post.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • RuSsMaN
    edited July 2007
    Hi, I'm Pete. Meet Re-Pete, and Three Pete.
  • phuz
    phuz Posts: 2,372
    edited July 2007
    RuSsMaN wrote: »
    You can say that again.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2007
    Stop Speaker Wire Abuse.
    Dial 1-800-WIRED4U
    Audio Enthusiast's Against Wire Abuse.
    AEAWA--Rocks.........
    OK--Just Kidding.
    RT1
