Speaker wire, which side is positive/negative?
impronto
i have speaker wire with one side with a stripe, the other not. which side is the standard for negative or positive? Thanks
Post edited by impronto on
It doesn't matter, just wire all your speakers the same.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
The trick is to always be consistant.
I always use the stripe side as my positive.
But as russ said, doesn't matter what you use for + or - as long as you are always consistant.Television: Mitsubishi WD-57732
Front R/L: Polkaudio RTiA7
Center: Polkaudio CSiA4
Rear R/L: Polkaudio FXiA4
Subwoofer: Polkaudio DSW600
A/V Reciever: Denon 2808
DVD/SACD: Sony Playstation 3 -
What they said. I always hook up the white stripe, or the side with lettering or other marking, to the red post.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Hi, I'm Pete. Meet Re-Pete, and Three Pete.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Stop Speaker Wire Abuse.
Dial 1-800-WIRED4U
Audio Enthusiast's Against Wire Abuse.
AEAWA--Rocks.........
OK--Just Kidding.
RT1
