how do I stop rattling windows, doors, and small animals?
rs159
rs159 Posts: 1,027
I just moved my sub to another place in the room which is about a 500% improvement over where it was before, smoother, louder, more musical, and decreased presence of null spots. Problem is now the windows and doors rattle like crazy anytime I turn it up to a listenable volume. This is very annoying. :mad: Does anybody have some tips on how to keep things like windows from rattling without completely replacing them?
Post edited by rs159 on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited January 2003
    Foam truck cap tape - works wonders. Slip in the noisy cracks and seams and behind stuff on the walls.
    SVS
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited January 2003
    Dont forget to go int he addict every once a year to renail the top of ur walls ;)
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • rs159
    rs159 Posts: 1,027
    edited January 2003
    wow... thanks Doc, that works great. Only problem is everybody who heard the system before thought it was a big cool factor to have everything rattling and shaking and jumping of the shelves like crazy and now they are dissapointed that everything is so "dead" and "quiet". Foolish mortals. :)
  • kberg
    kberg Posts: 974
    edited January 2003
    I'm waiting for my goldfish to "surface" from U-571 depth charges. So far, they're doing fine. :)
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2003
    Originally posted by Dr. Spec
    Foam truck cap tape
    Where can it be found?
    More later,
    Tour...
    Vox Copuli
  • Dr. Spec
    edited January 2003
    any auto parts store - sticky on one side, peel off tape covering protects the adhesive - like weather stripping
    SVS
    F1nut Posts: 51,763
    edited February 2003
    Another foam product to try would be the stuff they sell to seal windows when you use a window A/C unit.
