Yamaha EQ-630 LED help needed
  • Systems
    Systems Posts: 14,872
    edited February 2007
    Ever hear of "Dean" guitars? I play and own them
    When I chose my user name Dean guitar player, the site cut off part of "player"
    Nice axes.:)
    Testing
    Testing
    Testing
  • Dean guitar pla
    Dean guitar pla Posts: 117
    edited March 2007
    Thanks, would you say these are radial leads? They look just like the ones pictured by DarqueKnight. Would the wedge style also work, I know I would have to solder them myself if the radial lead type cannot be matched
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2007
    Like DisneyJoe said, look at the bulb and get the size, Ma rating, and match the style. Good luck.
  • robertm
    robertm Posts: 2
    edited July 2007
    Hi,
    I have the same equalizer, the EQ630. Mine is doing the same thing, the right side display is out. Did you fix yours? Did you do it yourself or send it somewhere?
    Trying to find out what to do with mine. If you sent it somewhere, where and how much did it cost you if you dont mind. If you fixed it yourself...where did you buy the parts and what did you buy? lot of questions, I know...thank you in advance!!!!
  • strider
    strider Posts: 2,568
    edited July 2007
    robertm wrote: »
    Hi,
    Dean/Bill/Ron hasn't been heard from for quite some time. He sold a bunch of vinyl, asked a few questions, ruffled some feathers, and rode one of those guitars off into the sunset.....
    Wristwatch--->Crisco
  • robertm
    robertm Posts: 2
    edited July 2007
    Thanks for the info Strider. I found this forum & thread last night when I was searching for info on the eq. thanks again! Robert
