Yamaha EQ-630 LED help needed
Nice axes.:)Dean guitar pla wrote:Ever hear of "Dean" guitars? I play and own them
When I chose my user name Dean guitar player, the site cut off part of "player"Testing
Testing
Testing -
Thanks, would you say these are radial leads? They look just like the ones pictured by DarqueKnight. Would the wedge style also work, I know I would have to solder them myself if the radial lead type cannot be matchedPolkersince85 wrote:
Like DisneyJoe said, look at the bulb and get the size, Ma rating, and match the style. Good luck.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Hi,
I have the same equalizer, the EQ630. Mine is doing the same thing, the right side display is out. Did you fix yours? Did you do it yourself or send it somewhere?
Trying to find out what to do with mine. If you sent it somewhere, where and how much did it cost you if you dont mind. If you fixed it yourself...where did you buy the parts and what did you buy? lot of questions, I know...thank you in advance!!!! -
Hi,
Dean/Bill/Ron hasn't been heard from for quite some time. He sold a bunch of vinyl, asked a few questions, ruffled some feathers, and rode one of those guitars off into the sunset.....Wristwatch--->Crisco -
Thanks for the info Strider. I found this forum & thread last night when I was searching for info on the eq. thanks again! Robert
