roth audio
JimBRICK
http://www.rothaudio.co.uk/
Anyone have any knowledge of them? The have and integrated tube amp with an ipod dock on it
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
2 watts shanling 10 watts roth, what speakers could you possibly run off these2 CHANNEL
Under construction -
Very efficient ones -- low-mid 90's sensitivity and higher. Full range drivers. No problem.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I am a little confused as to why you would take a I-pod and hook it up to one of these units. Not trying to dog you, or anybody for that matter, but isn't this the same thing as trying to make chicken soup out of chicken ****?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Actually alot of people have been replacing cd players with ipods on other forums such as Audio Circle. Red Wine Audio also does mods to these called the Imod which are supposed to be phenomenal.
Apperently the 4th and 5th generation use Wolfson DACs, plus all Ipods are battery operated for darker backgrounds.
I personally have had very good experiences using a Ipod as a source. -
And, don't forget the convenience of having hundreds of albums at your finger tips.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Not a fan of Wolfson dac's or DSD decoding or Ipods in an audiophile setting."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
The music server is a hot topic on alot of forums and seems like the next logical step. I'm looking forward to it.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
It seems as if all things convenient have a way of taxing the almighty end result.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
To each his own, but I have certainly been swayed (thanks again, Polk Paul) to the point that the Ipod may not be the "end all; be all" but that it could and should be an integral part of a well-rounded upper-mid-fi and hi-fi system especially if ALE format is used for your recordings. I used to believe that there was no way an Ipod could keep up with a decent digital source, i.e. Rotel & Bel Canto, but after reading Polk Paul's article and taking the plunge I'm convinced there is very serious merit in having an Ipod available as a source.
On that note, I have to say my experience with the Ipod as a source has been very positive thus far. I've noticed that on the earbuds that come with the Ipod that songs are actually a little bit clearer, but obviously not as listenable as on the SRS's. The clarity can't make up for impact, dynamics, scale, and presentation. I imagine that some room treatments and a crossover upgrade on the SRS's will make this a very moot point
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I'm sure the IPod and other similar portables are very good at what they are designed to do but they have no place in a reference rig. Convienence and portability are unmatched and I suppose using an outboard dac would best. I just don't understand why when some of us go to great lenghts to tweak our systems with proper cables, anti vibration devices, isolation devices, etc., then use an IPod as a source.
It's like building a great suspension on a race car and then putting Farm & Fleet tires on it.
This is just one person's opinion
Hook up your iPod or MP3 player with a Y cable (1/8 stereo to RCA) and have a listen. I've connected my Dell DJ this way and it sounds fine. I also use a stock Squeezebox as a music server and love it. Heiney, isn't it your brother who built a PC to use as a digital music server? Does he just get his tunes to his rig in a more Audiophile Approved way?
Yep, but he routes it thru a $1300 outboard dac. It makes a diff. I'm not opposed to the units as a transport, but the internal dac leaves a lot to be desired in both the Ipod and Squeezebox (IMHO)."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Not a big fan of the I-pod generation.But will add that most things sound better thru earbuds and better yet,headphones.They take the room out of the equation and give a more 3-d soundfield.I for one don't enjoy walking around with crap attached to my ears all the time.You miss out on all the other things life has to offer.HT SYSTEM-
lsi 9's -
Some of you may be forgetting that the ipod can play lossless files like .WAV and Apple Lossless. It is not just an MP3 Player.
I say that when I absolutely hate the damn thing and would never buy one in a million years, but not because of the sound... but the interface is just horrid and itunes has to be about the worst digital music software anyone could ever come up with. Why the hell can't you just plug the f'ing thing in and copy your files over like it was just an external HD!?!? Why do you even *need* special software to begin with? Ok, maybe I am ranting, but then again, I am a minimalist.
I think the ipod playing lossless format sounds OK, I didn't mind it (the sound) when I helped a friend get one setup. Those docks, being tubed, probably take a bit of the edge off. -
Didn't forget that at all. Apple lossless is not truely 100% lossless as they say. It's close but not quite. Again no problem per se with the units but the internal components are no where near audiophile."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Best one I've read for awhile
Vinyl, the final frontier...
The image provided by earbuds and headphones is so artificial it's almost annoying.
Also, can someone please enlighten me as to how to connect my Ipod to Bel Canto DAC? H9 and others have talked about it, but no one has shown me a definitive method of doing it. The guy at the Ipod store understood what I wanted, but was clueless as to whether a product out there did it.
