Hybrid SL2500...worth it?
maluckey
maluckey Posts: 11
edited July 2007 in Vintage Speakers
I just got an Email back from Polk regarding replacement tweeters for my venerable Monitor 12 Series 2 (I damaged one when I moved to a new house). I was told that the current SL2500 is a hybrid of the SL3000 coil and the dome of the SL2500. I like the old speaker, but I have heard better. Has anyone heard the hybrid SL2500? If so, is it an improvement?
Asus Xonar D2X (source)
Adcom GFP 565 pre amp
2 x Adcom GFA 555 II (bridged mono) amps
Polk Audio Monitor12, Series 2, speakers with RDO 198 tweeters
Post edited by maluckey on
  • Polk65
    Polk65 Posts: 1,405
    edited July 2007
    Welcome to Club Polk. What is the part number they offered? I'm guessing RD0198-1 which will look like post #2 in this thread http://www.polkaudio.com/forums/showthread.php?t=25377
    BTW, keep your M12 S2 for someone special. They don't show up too often.
  • maluckey
    maluckey Posts: 11
    edited July 2007
    Thanks for the link!
    I have no intention of giving up the speakers. I'm the original owner, and they are still solid speakers. I just figured that if I had to replace both, i might as well experiment with an "upgrade" if at all possible.
    for the moment I'm just going to replace the damaged part with the stock parts, but still plan on trying a different setup of tweeters when I get back home.
    F1nut Posts: 51,699
    edited July 2007
    The new RD0 tweeters are a vast improvement, get two.
  • maluckey
    maluckey Posts: 11
    edited July 2007
    Nevermind! By RDO I assume you mean the SL 2500 hybrid?
    F1nut Posts: 51,699
    edited July 2007
    Search away....http://www.polkaudio.com/forums/search.php?searchid=896793
    No tweaking or modding needed, but upgrading your crossovers isn't a bad idea.
  • maluckey
    maluckey Posts: 11
    edited July 2007
    Thanks for the tips!
