Cool DIY sub for music...
VR3
I want to make some stereo subs...
Basically Brian is successfully - pretty much giving me "free" parts to build my own subs...
Before it is over, I will have two 15" PRs and probally two 15" actives ----
So with this in mind...
What kind of sub can I make with this...
20"H x 26"W x 17"D - those are the dimensions of the VMPS Original Sub that uses the same config...
I guess I could recreate those if I wanted to - wouldnt be hard and I could build them better.
Slot load the PR -- but that can kind of give you an idea as far as cabinet volume and so forth...
Perhaps if someone can cook up something that rolls off around 30hz... I'd dig that...
Post edited by VR3 on
Perhaps I can make a huge low frequency subwoofer??
tune it REALLY low -- make it like a gazillion feet tall?
Throw me some ideas!
That would obviously be for HT...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I need specs for the active driver and pr, you can't determine much until you have that. Overall Q and Vas are very important if you want it to sound right.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
cough cough....infinite baffle...cough coughLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
If it is strictly for music and not HT then I would go with a low Q sealed design.Testing
Testing
Testing -
didn't you just get a ML Depth?
Isn't that like having a Ferrari in the garage and then talking about building a franken-car because you came across some free tires and engine parts?
Enjoy the depth! Forget about the DIY.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
How about this!
http://videos.streetfire.net/category/Trucks%5e%5eOffroad/2/752b597e-b098-4744-b08e-995b00cd84ff.htm:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
Thats way cool,I want one.That design should also reduce room mode problems.Testing
Testing
Testing -
Why would they use a box? I thought one advantage is that dipoles dont need an enclosure, just a baffle. Also seems kinda a waste too since you could do the samething with 1 18" rather than all of those smaller drivers.
