Cool DIY sub for music...
VR3
VR3 Posts: 29,503
edited July 2007 in DIY, Mods & Tweaks
I want to make some stereo subs...
Basically Brian is successfully - pretty much giving me "free" parts to build my own subs...
Before it is over, I will have two 15" PRs and probally two 15" actives ----
So with this in mind...
What kind of sub can I make with this...
20"H x 26"W x 17"D - those are the dimensions of the VMPS Original Sub that uses the same config...
I guess I could recreate those if I wanted to - wouldnt be hard and I could build them better.
Slot load the PR -- but that can kind of give you an idea as far as cabinet volume and so forth...
Perhaps if someone can cook up something that rolls off around 30hz... I'd dig that...
Post edited by VR3 on
    VR3 Posts: 29,503
    edited July 2007
    Perhaps I can make a huge low frequency subwoofer??
    tune it REALLY low -- make it like a gazillion feet tall?
    Throw me some ideas! :)
    That would obviously be for HT...
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2007
    I need specs for the active driver and pr, you can't determine much until you have that. Overall Q and Vas are very important if you want it to sound right.
  • ohskigod
    ohskigod Posts: 6,505
    edited July 2007
    cough cough....infinite baffle...cough cough
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2007
  • Systems
    Systems Posts: 14,872
    edited July 2007
    If it is strictly for music and not HT then I would go with a low Q sealed design.
    Testing
    Testing
    Testing
  • AndyGwis
    AndyGwis Posts: 3,655
    edited July 2007
    didn't you just get a ML Depth?
    Isn't that like having a Ferrari in the garage and then talking about building a franken-car because you came across some free tires and engine parts?
    Enjoy the depth! Forget about the DIY.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited July 2007
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • Systems
    edited July 2007
    SLOCOOKN wrote: »
    Thats way cool,I want one.That design should also reduce room mode problems.
    Testing
    Testing
    Testing
  • Meeks32
    Meeks32 Posts: 330
    edited July 2007
    Why would they use a box? I thought one advantage is that dipoles dont need an enclosure, just a baffle. Also seems kinda a waste too since you could do the samething with 1 18" rather than all of those smaller drivers.
