HDMI cable: cheap Toslink or Monster?
Gabor
Before spending (or wasting) my money on a very tempting Toslink HDMI cable on Amazon.com, I'd like to hear your opinions and experiences with cheap versus brand name HDMI and optical cables.
This is digital, folks, does it really matter?
And if it does, how, and how much?
I just upgraded my old battered JVC receiver for a Yamaha rx v661 for my Rti 10 babies, and 'd like to replace my old analog cables with digital ones (at this point it is hard to believe that the sound gets any better, but I still have the bi-amping option besides the digital cables - just want to enjoy each consecutive level).
Post edited by Gabor on
I use Monoprice.com for all my digital interconnects. SignalCable and Alpha Core for analog."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I would pass on the Monster and try Blue Jeans Cable.
Excellent cables for the money.
http://bluejeanscable.com -
Monoprice.com
Thank you guys, I just checked out the sites you'd suggested. Blue Jeans Cable is very informative, monoprice.com is awsome with its prices and selection.
I'll pass on Monster. -
before you buy, check this hdmi cable from panasonic.
http://www.amazon.com/Panasonic-RP-CDHG15-High-Speed-Cable/dp/B000GKQL70/ref=pd_bbs_1/002-5008667-2381627?ie=UTF8&s=electronics&qid=1184178495&sr=8-1
for a 4.9f
or
http://www.amazon.com/Panasonic-RP-CDHG30-High-Speed-Cable/dp/B000G62F88/ref=pd_bbs_3/002-5008667-2381627?ie=UTF8&s=electronics&qid=1184178585&sr=8-3
for a 9.8f cable.
why do I mentioned this cables, these are hdmi 1.3a certified.
I have the 4.9f and after comparing to another generic brand this cable had better picture and resolution.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
All hdmi cables are the same , if you buy any expensive cables all you are paying for is the name..My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Really?? So, the wire(guage) size and length of runs don't matter?:rolleyes: -
supposedly, HDMI is purely digital, so as long as the 0s and 1s are getting from point A to point B, nothing else should matter.
Basically, it should either work 100% or not work at all. But, I guess you could say the same for Coaxial and Optical cables, and people spend out the butt for those.
I think having a nice, thick cable gives me good piece of mind, so I paid the extra couple bucks to get my HDMI and HDMI to DVI cables from BlueJean.
I did get suckered into buying a Monster HDMI cable for $120 two years ago when I bought my Plasma and Samsung upconvert player. Returned it the next day. Absolutely the worse money you can spend.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Andy,
You are correct, and this is where the size of wire and length of runs come in. In most cases a 28g HDMI cable will suffice in 10' or shorter lengths, longer runs (i.e 50') need larger guage of wire to keep the signal from degrading. Usually causing a form of "pixelization". -
With hdmi anything under 10ft really won't matter the signal will remain the same,
And for longer lengths the wire size must increase of course that goes without saying.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
:cool: Just don't want people to think that "any" cable will do, all depends on your application. -
Guys, not to disagree,
I bought a Panasonic dvd player that has 1.3a output, also bought a Panasonic 1.3a cat 2 hdmi cable and a new sony 60”tv, and I have to say I went back and forth testing the Panasonic cable vs a cheaper hdmi cable that was not rated 1.3a and I can see a big difference in the picture. I think if everything you own is hdmi 1.1 or 1.2 then a you will not get a better picture or sound.
However I don’t see the point on buying a 100$ dvd player an paying 160$ for a monster cable, or any other cable manufacturer for that matter, I don’t even care is if made out of gold.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
TV: Sony KDS60A2020
DBP: Sony DBP-S350
From what I read, all the HDMI cable needs is the offical standards mark and its 100% good to go no matter if it costs $25 or $300.Testing
Testing
Testing -
Well, to me it looks like an overkill to by $50 or so cable for a short distance, for what I need (2ft).
Digital signals (in the form of square waves of the change of voltage) will be conducted for this short distance with no attenuation. Pixelization (or decrease of resolution), as MikeC78 mentioned, and loss of signal is due to the rounding of these square waves to the degree that the decoder can't read them anymore.
But I just came across an interesting information concerning optical cables. They conduct signal on the analogous way. What a surprise! Maybe there is a reason why Blue Jeans Cable recommends coaxial instead off optical cable.
What do you think? -
Mono-price here...
But don't be like me and break off your HDMI connection from your DVD player:mad:Cambridge Audio AZUR 640R
KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
Sub Outlaw LFM2
Panasonic Plasma 1080i (50u)
Sony DVP-NS70H (DVD)
Belkin Pure Audio PF31 Line Conditioner -
monoprice is the place to go for all cables.
I've saved at least a grand in the last yr using monoprice for cables and switchers. -
I used the standard, very thin HDMI cable that came with my DirectTV high-def box to temporarily connect my Sony XBR 60". Next day I replaced it with a heavier $150 6' cable from Tweeter with no difference that I can tell. For shorter distances, save your money.
