Bass Shakers - Buttkicker 2 and Aura
kberg
Hey All,
Anyone have this product or know anybody that does? Check it out at:
http://www.smarthome.com/82572.HTML
There is also an Aura product at:
http://www.smarthome.com/8249.html
Just wondering if either/both of these products would be a relatively inexpensive enhancement, or just a piece of JUNK!
Opinions/suggestions welcome.
Thanks.
Thanks.
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Sub: SVS 20-39 PC+
Post edited by kberg on
We talked about these a couple weeks ago. They are not that expensive for the units. The catch is that they require LOTS of amp power. By the time you buy the amps and wires and "vibration" units. You should just buy a subwoofer that will "vibrate" the entire room.;)
I hear ya. Thanks!Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
Remote: Logitech Harmony H688 -
Yeah Kevin!!!! Like like the Vamp man has - the bruiser 1200. Get your spend on and you won't need to stinkin' buttkickers!!!! "What we do in life echoes in eternity"
SVS -
kberg,
I went to a home theater showroom while I was a Disney and they had the buttkickers. I looked for them because I was impressed. When I found out the cost of the unit and then an additional power amp I decided it was'nt worth it. If like someone else said,( you brought a good sub)it would do the same thing.JmasterJ Polk to the Death -
I went to epcot....and u'd swear the bass shakers were the subwoofer hooked up to those POS bose speakers. Thats where all the vibrations came from! lol! That subwoofer wasn't doing crap!Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
I bought some of the Aura bass shakers from Parts Express for a song, they are rated for ONLY 25wpc, I mounted 4 of them to my couch frame and use a NAD 3020 (25wpc) amp.
I am not saying they replace a subwoofer, but they are the coolest thing I have used in a while. I have a pair of LSi9's, they have very nice bass for the small speaker that they are, but not the deepest, and there is no vibrations shacking the walls.
the LSi9's plus the bass shakers is a very cool set-up, I can "feel" the bass, and it seems as if it comes from the speakers.
I have been to Epcot's "Ultimate Theater" what a joke.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
