RIP Old Pioneer VSX-4400 Receiver
Mike682
Mike682 Posts: 2,074
edited July 2007 in Electronics
Ok so I set up my basic garage system. Bought these outdoor speaks at ratshack which aren't bad for $50. I ran the set-up with no problems during our daughter's Christening. System worked great. I went to listen the other day while doing some yard work and noticed something was wrong: the right channel is blown. No sound, nothing. Swapped speaks, checked wires, etc., still no sound from right channel.
Before I toss this into the trash, is there anything internally I can check? It does have some sentimental value as I was in high school when I bought it. I had it on layaway and every week I would run to the electronics store to put more down until I was able pay it off and take it home:D
Here is a pic
http://www.polkaudio.com/forums/attachment.php?attachmentid=17687&d=1152277837
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Post edited by Mike682 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2007
    Work all switches as this seem odd to me the right channel died after nothing. Also see if any of the inputs work the right channel at all, this will tell you if its the amp or something else.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Mike682
    edited July 2007
    I'm gonna switch inputs to see if there is a diff.
    So far, just out of curiosity, I changed the wires from speaker A to speaker B with the same result.
    Oh yeah, first thing I checked was the the balance levels:D
    Mains: polk R30
    Center: polk CSi3
    heiney9 Posts: 25,396
    edited July 2007
    Check for internal fuses, if so measure with an Ohm meter to see if one is blown. Replace with exact same value if that's the case.
  • jcaut
    jcaut Posts: 1,849
    edited July 2007
    Does it have a relay that keeps the outputs disconnected for a second or two after you power it up? I can't really tell from the picture, but it might be the black rectangular thing right in the middle of the picture. Usually you can hear them click. I have had some trouble with those in the past, though usually it results in scratchy or intermittent sound in one or both channels, rather than just a dead channel. I've had that issue on two older receivers (well, integrated amps actually), both Pioneer (but probably just by coincidence).
    Jason
  • Mike682
    edited July 2007
    thanks for the replies everyone
    I found the problem. I was using an XM radio home dock station as my input and the mini jack connection was loose. Because it was loose it was only transmitting the signal over the one channel.
    I was moving it when I was running all my checks and bam, the right channel went on. I moved it back and forth and the right channel would go in and out.
    Bought a new dock station and everything is ok.
    :D
    Mains: polk R30
    Center: polk CSi3
  • disneyjoe7
    edited July 2007
    See it pays to double check everything :) Glad to see you got it fixed.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited July 2007
    Damn! I was gonna go through your garbage!:eek: :D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Mike682
    edited July 2007
    You are right, it does pay to check every little thing. That was the last thing I thought it would be. Usually loose mini jacks will give off a scratchy sound
    Mains: polk R30
    Center: polk CSi3
  • Mike682
    edited July 2007
    :D:D:D:D:D
    Mains: polk R30
    Center: polk CSi3
