What brand of solder do you use.
engtaz
What brand of solder do you use when updating your speakers and wires.
engtaz
Post edited by engtaz on
I use Cardas,,because I had a ton of it.:)JC approves....he told me so. (F-1 nut)
Does that mean you give a better price then soniccraft.com? LOLengtaz
No, that just means that I bought waaay too much when I did my first 1C crossover and binding post upgrade,I used the Cardas ccgr short IIRC.The last ones have the Vampire BP-Hex posts on them,which I'll be selling sooner than I thought,because of this "vinyl" addiction.:)JC approves....he told me so. (F-1 nut) -
Which binding post do you like the best?engtaz
I think that it's a matter of personal preference. The Cardas are more expensive than the vampire,,and as Jesse mentioned,,when you solder the wires to the binding post,don't have them "seated",as that particular connection requires some heat IIRC.But to answer your question,I like the cardas because of the "fit and feel", and to me were easier to install.JC approves....he told me so. (F-1 nut)
WBT 4% Silver SolderRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
Radio Shack. Silver bearing solder for signal connection, and the regular stuff for electrical connections.
