What brand of solder do you use.
engtaz
engtaz Posts: 7,674
edited July 2007 in Vintage Speakers
What brand of solder do you use when updating your speakers and wires.
engtaz
Post edited by engtaz on
  • george daniel
    george daniel Posts: 12,096
    edited July 2007
    I use Cardas,,because I had a ton of it.:)
  • engtaz
    engtaz Posts: 7,674
    edited July 2007
    Does that mean you give a better price then soniccraft.com? LOL
    engtaz
  • george daniel
    edited July 2007
    engtaz wrote: »
    No, that just means that I bought waaay too much when I did my first 1C crossover and binding post upgrade,I used the Cardas ccgr short IIRC.The last ones have the Vampire BP-Hex posts on them,which I'll be selling sooner than I thought,because of this "vinyl" addiction.:)
  • engtaz
    engtaz Posts: 7,674
    edited July 2007
    Which binding post do you like the best?
    engtaz
  • george daniel
    edited July 2007
    I think that it's a matter of personal preference. The Cardas are more expensive than the vampire,,and as Jesse mentioned,,when you solder the wires to the binding post,don't have them "seated",as that particular connection requires some heat IIRC.But to answer your question,I like the cardas because of the "fit and feel", and to me were easier to install.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited July 2007
    WBT 4% Silver Solder
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited July 2007
    Radio Shack. Silver bearing solder for signal connection, and the regular stuff for electrical connections.
