has anyone done an A+b comparison?
JimBRICK
JimBRICK Posts: 1,543
edited July 2007 in 2 Channel Audio
I'm wondering if anyone has done am A+B comparison between B&W and polk LSI series?
What were your opinions. I said screw it and put everything up for sale. I'm going to either purchase the lsi15's or the B&w 683
Going from a 5.1 to a straight 2 channel system for a while and then I'm going to build the home theater. With this move we may be having to do it'll be easier.
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • McLoki
    McLoki Posts: 5,231
    edited July 2007
    From what I have heard of B&W - I would say they are more similar to the Paradigm's than LSi's in sound. (The B&W's seemed to have a briter sound and mated best with laid back equipment. - The LSi's are laid back to begin with and mate best with very detailed (i.e. more brite) equipment.)
    All in my opinion of course. Personally, I liked the LSi's more, but to each their own. B&W makes some very nice speakers. (just kind of pricey in my opinion for what you get) If you really dig the B&W sound, I would check out and compare against the Paradigm Studio series speakers for a similar sound for less cash.
    tonyb Posts: 33,072
    edited July 2007
    Well,for me.you have to move up the b&w line for some quality sound.I think the lsi series is a few steps up over their 600 series.Of coarse,with the usual disclaimer,to each his own.If you plan on building a HT around your 2 channel setup,then the LSI line will be right at home.
  • mantis
    mantis Posts: 17,394
    edited July 2007
    I have alot of experience with both companies.
    Polk Lsi are great speakers and very detailed. they do require good clean power to hear what they can do. They are also 4ohm load so most receivers are out of the question. I have owned them and loved them. They really don't have any musical weakness. They play everything great. I would own them again. They are also one of those middle of the road speakers that you could keep for the rest of your life. You can go pretty high end on the gear side and not have to replace these speakers. Rotel and B&K go very well with these speakers.
    B&W 600 series as I have not heard the new 683's , I have heard all of there older models. In general B&W speakers are easy to drive and very hard to get to sound right. They are extremely picky with what you put on them. they can sound like **** or like one of the very best sounding speakers you have ever heard. I have a love hate thing going for B&W. I come close to buying them and find something else. But they keep me coming back to check them out so there is alot there to be desired. I find rock music to lack a bit on B&W speakers. They do it but others do it much better. Softer side of music they shine like no other. Probably the best classic, jazz speakers in the bussiness.
    It's a toss up man. You gotta hear them for yourself. Personally I would think about the kind of music you listen to and get a closer answer you will.
    I like em both for different reasons. I would probably go with the B&W speakers as I haven't owned them before.
    Dan
    Dan
  • JimBRICK
    edited July 2007
    and seeing I can get the LSI's at cost I think I just got my answer, thanks :)
    I've been on the fence for alot of months and I have someone coming to look at some on the gear I'm selling. So as soon as this transaction is done my lsi15's will be in the mail. I also worked out a good deal on some lsi7's which will later go in the back.
    I've been noticing ALOT of these carver amps going on sale on ebay lately with 400 watts @ 4 ohm loads. SO I'll probably bid on one of those or the adcom 555II I've been talking to a forum member about. Now just get my tube preamp and I'm done for now.
    if I could find a ROTEL RB-1080 for a good price thats what I really want
    2 CHANNEL
    Under construction
  • JimBRICK
    edited July 2007
    Ok well my speakers are sold and I'm sending my order in for the lsi15's on monday. I'm going to buy a adcom555II off a member who pm'd me to power them. If I still want to watch movies and tv using this 2 channel system what preamp should I be looking for or should I just use the t743 NAD reciever I have?. cause this way I can still run a sub. any help is appreciated
    http://207.228.230.231/info/NAD_T743.pdf
    link to my reciever
    Jim
    2 CHANNEL
    Under construction
  • Refefer
    Refefer Posts: 1,280
    edited July 2007
    Any system that can play music great can play hometheater great.
    Any system that can play hometheater might be able to play music well.
    Any preamp that you use that sounds good for music should sound good for home theater as well. As for hooking up a sub, you can always use two Y-splitters from the RCA outs on your pre, combine them, and send them to your sub. The huge advantage of this is you could turn off your sub when listening to music, and turn it on for hometheater, all without having to juggle equipment, while having an excellent two channel preamp.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • JimBRICK
    edited July 2007
    I see you have the rotel 980, I'm talking to someone about instead of getting the adcom getting the RB-890. I figure its plenty of power for the lsi15's.
    I could also use the amp for the fronts and power my center and rears later with the reciever. My NAD is plenty powerful enough for the lsic and lsi7's for the rears. My reciever has the preouts, so I think I have the plan. But what I need to know is do rotel and NAD mess well together?
    2 CHANNEL
    Under construction
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    http://www.polkaudio.com/forums/showthread.php?t=54864
    This is what would be a better amp.
    engtaz
    treitz3 Posts: 19,993
    edited July 2007
    B&W speakers to me yield a tarp put over your best speakers. Not a big fan here.
  • JimBRICK
    edited July 2007
    engtaz wrote: »
    I'm getting the rotel for 200 shipped I get yours if you match the price LOL
    2 CHANNEL
    Under construction
  • JimBRICK
    edited July 2007
    treitz3 wrote: »
    I'f you heard the 800 series I heard with the proper amplification you'd change your mind. I listened to them in sudbury a few months back at a dealer and its the first time I heard a system that knocked me on my ****. I honestly felt I was right there in the studio. Theres no way I would ever spend 23000 bucks or could I offord to throw that kind of money at a 2 channel system
    2 CHANNEL
    Under construction
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    That's not mine. If it was mine I would not be selling it.
    engtaz
    edited July 2007
    JimBRICK wrote: »
    I have and I still think that they are musically compromised.
  • mantis
    edited July 2007
    treitz3 wrote: »
    Can you explain what you mean by this??? B&W are one of the worlds best speakers. There 801's are incredible. I have been around high end for a long time and B&W are right there with the very best.
    there lower end speakers are also very good and could be considered one of the very best dollar for dollar. They hold there own with anyone.
    Personal taste does come into play but musically there one of the best.
    Dan
    Dan
    edited July 2007
    Yes. They sounded flat to me. I couldn't really get a good A/B test to what I was trying to accomplish concerning SACD because I tested the system [no synergy] through B&W speak's. The top end had no High Fidelity and I was disappointed with the test and therefore could offer no results. It sounded as if the top frequencies had a tarp, or a blanket covering the highest frequencies. The upper midrange was a struggle to hear at times. Clarity was just not top notch. Sometimes price does not please my ears. The end result does.
    The front end and source was Marantz.
  • JimBRICK
    edited July 2007
    You can't use mid level electronics like marantz to test B&W speakers. Its like using unleaded gas in a jet. the pre and power amp they used in the dealers I was at were mcintosh and the amp almost cost as much as my first car
    2 CHANNEL
    Under construction
    edited July 2007
    Can you test the LSI's on the same gear mentioned? This will answer your question.
  • JimBRICK
    edited July 2007
    I hate to say this in a polk forum but you cant compare a lsi speaker to an 800 series floorstanding speaker. but if I asked the dealer he would let me bring my speakers in to hear with the mcintosh
    2 CHANNEL
    Under construction
  • Kahuna
    Kahuna Posts: 35
    edited July 2007
    JimBRICK wrote: »
    Theirs one up here in Minnesota! (I found this while scouring Craigslist):
    http://minneapolis.craigslist.org/ele/368100071.html
    edited July 2007
    Kahuna wrote: »
    That's the same thing as the 4.0, TFM-42 and the TFM-45. Different faceplate is all. The 4.0 and the 42 have runway lights and the 45 has VU meters. Internally they are the same.
    Price is close to average considering recent prices for Carver gear, especially since it is mint. (as he claims)
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2007
    JimBRICK wrote: »
    Jim,
    You've evidently never heard Marantz reference gear. I think that $7k SACD/CD and $16k monoblocks aren't most peoples mid-level gear.:rolleyes:
    http://us.marantz.com/Products/616.asp
