Biamping redux
NeilGabriel
NeilGabriel Posts: 1,487
I thought I understood this biamping stuff until I started thinking about it. My question is if you are biamping with a 2 channel preamp, how do you split the L/R preamp outputs to be able to biamp the speakers? Do you use a Y splitter coming off the preamp outputs?
Post edited by NeilGabriel on
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    y spit out of the preamp for both channels. send 2 left rca's to the 2 channel amp for left and send 2 right rca's to the 2 channel amp for the right speaker. Remove speaker shorting clips and plug speaker wires for L/R to upper and lower speaker terminals.
    engtaz
  • NeilGabriel
    edited July 2007
    makes sense to me! thanks....
