My broken tv
dholmes
dholmes Posts: 1,136
edited July 2007 in Electronics
Well about a month ago I told everyone about my broken tv,well I asked two different repair men & they told me it would cost between 300-400.00 $ to fix it. The tv is about 6 yrs old is it worth fixing? thanks happy 4 th!!
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited July 2007
    I think that would depend on how much you have to spend on a new one if you went that route....There are a lot of deals floating around out there on new TVs, DLP or LCD....Where in Kentucky are you?
  • dholmes
    edited July 2007
    I paid about 3000.00 for it,Im in the Mammoth Cave area. The bad thing is all the repair men want me to bring the tv to them!! its weight is 450 lbs! thanks
  • Bill Ayotte
    edited July 2007
    Damn, what the hell is it? That's a lot of weight to huff down to a repair guy....They had a great deal on a lot of 720p TVs at CC and BB...About in the $1000 range for a 50".....
  • dholmes
    edited July 2007
    Its a 65 in crt rear projection.
    tonyb Posts: 33,072
    edited July 2007
    Well,tack on another 150 bucks for a service call fee if you want them to come to you.Thats tweeter's going rate anyway.
  • JimBRICK
    JimBRICK Posts: 1,543
    edited July 2007
    you can get a 60 inch new for around 1000 bucks
    so replace new for 600 more or go new style for about 2000
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2007
    i would replace it, while youre at it, give front projection a thought also. May as well go bigger while opportunity knocks brother. You wont regret it.
  • dholmes
    edited July 2007
    Thanks everyone, I have a front proj in my ht, I just need to do someting about the tv in the living room! I guess Ill have to take it to the dump & get a new one.
  • JimBRICK
    edited July 2007
    try and sell it even broken you might get a couple hundred buck since you know whats wrong with it and how much to fix
    2 CHANNEL
    Under construction
  • AndyGwis
    AndyGwis Posts: 3,655
    edited July 2007
    Yeah, sell it as-is on Craiglist for a couple hundred, then go get yourself a nice LCD, DLP, Plasma, or whatever else will fit best. You can get a lot of TV for $1000 now. Vizio has 42" Plasmas for around that much, or a lot of DLPs, or some LCDs.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
