Which comes first...the receiver or the speaker.
auto_pilot
auto_pilot Posts: 256
edited July 2007 in Electronics
Okay...I've been mulling this question for awhile now:
Which is more important the AVR or Speakers? After much consideration I think the speakers are more important. I've heard a relatively weak reciever with 1st rate speakers, and the speakers sounded great. Not the best, but good nonetheless. Could the reverse be true? Can a truly powerful, nicely processing, and dynamic receiver make marginal speakers sound better? I wouldn't think so.
Thoughts, comments, yada yada yada...:)
Cambridge Audio AZUR 640R
KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
Sub Outlaw LFM2
Panasonic Plasma 1080i (50u)
Sony DVP-NS70H (DVD)
Belkin Pure Audio PF31 Line Conditioner
Post edited by auto_pilot on
  • phuz
    phuz Posts: 2,372
    edited July 2007
    I think you're right.
  • Refefer
    Refefer Posts: 1,280
    edited July 2007
    A lot of bad speakers can sound reasonably good with quality watts going into them. I've also heard great speakers sound like poo when driven with crappy electronics.
    It's a toss up. It really depends on the speakers and it really depends on the amplifier.
    I wouldn't drive a pair of LSi's or Maggies without a quality amp.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Where are you planning to end up? Real nice speakers need an amp. Good speakers can be run from a good AVR. Let us know what you want to have for speakers. Don't do like I did upgrade, upgrade, upgrade. Get it done right the first time. It cost a lot less!
    Ben
    Ben
  • AndyGwis
    AndyGwis Posts: 3,655
    edited July 2007
    tough call. I guess if I had to spend money on one thing and then not upgrade anything, I would get very nice speakers over very nice electronics (if I had to spend the majority on one thing or the other).
    But, that being said, in my system I went the opposite way knowing I would likely upgrade at some point. So, I now have some very mid-fi speakers (Polk Monitors) with pretty nice electronics (B&K amp, HK 635 AVR, XA1 source).
    You really need to find balance, though, between speakers and electronics. Why have a weak link when you can spend just a little more to have a nice, balanced setup?
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • auto_pilot
    edited July 2007
    AndyGwis wrote: »
    I agree...My AVR definately better than my speakers...My limitation was room size, and asthetics, etc. I couldn't go front towers due to my room setup. Otherwise I probably wouldn't have gone KEF. However, I want to get nice quality towers to run off my amp for purely two channel listening when size of room allows for it.
    What did it for me is that I went to Magnolia HiFi and listened to a pair of Martin Logan Ribbon speakers with a Denon 2307 pushing them:eek: The transparency, soundstage, clarity, were excellent. But I don't think the Denon was truly pushing everything out there like a high end reciever could do.
    Sub Outlaw LFM2
  • AndyGwis
    edited July 2007
    Well, for two channel, you may think of putting a sepate system in a separate room, if space and money allows.
    I decided to focus on my 2-channel setup as I found it was just a totally different animal than HT. I also found my midfi HT to be adequate while my 2-channel taste are a little more high-brow. Couldn't afford to build a 5.1/6.1/7.1 system with high end gear, but could piece meal a very nice 2-channel rig together to satisfy my musical tastes.
  • auto_pilot
    edited July 2007
    ben62670 wrote: »
    Ben
    Ben...i landed on my KEFs...clarity and soundstage are good...but I was listening to my buddies Energy Take speakers driven by his Denon 3806...and I could tell I was missing a full range of sound, and sheer presence of the HT listening. The Energy's sounded forward IMO, but not bright. He has towers, and I have bookshelves...so I don't think its a fair comparison...Let a lone when it comes to pure two channel listening.
    Sub Outlaw LFM2
  • auto_pilot
    edited July 2007
    AndyGwis wrote: »
    That is the danger Andy...spending another $5K on a separate rig. I can probably sell one of my kidneys to get it going ;) I bought my AVR because its suppose to do both reasonably well. I need to listen to a good two channel system to see what I'm missing out on.
    Sub Outlaw LFM2
  • madmax
    madmax Posts: 12,434
    edited July 2007
    You can put a decent 2 channel system together for almost nothing. Of course over time it will tend to grow. :)
    madmax
    Vinyl, the final frontier...
  • auto_pilot
    edited July 2007
    madmax wrote: »
    madmax
    Sounds intriguing...I just need my all-in-one system to mysteriously break so I can justify an allocation for a new rig.
    Sub Outlaw LFM2
  • mantis
    mantis Posts: 17,374
    edited July 2007
    I think the speakers are more important but they both goo hand in hand.
    The trick to getting good speakers and powering them with a lower end receiver is having 8 ohm speakers. If you get Rti series speakers, then you can run them with just about anything. If you get LSi, you will have many problems and they will sound like **** on lower end stuff.
    This applies to any brand speakers you get. Just using Polks as an example. Speakers are the most important thing in the chain. If they suck, then no matter what you put behind them is not going to shine.
    Dan
    Dan
  • rskarvan
    rskarvan Posts: 2,374
    edited July 2007
    I've never heard an AVR. I listen to speakers.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited July 2007
    Speakers!
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
