Warning Replacement MW woofers
ben62670
Hey guys I just bought some MW6503 drivers for my project, and the surrounds don't have the notches cut out. When I installed them I tightened them down, and backed off a hair. I wasn't home for a while, and the AC was turned off. Later I was playing some music, and could hear a farting noise. I looked at the drivers and some of them the rubber wrinkled to the point where air could escape. Luckily I turned most of the screws back enough that I didn't have more damage. If you get replacement woofers install the screws most of the way, and take an exacto knife and cut out the rubber that would be under the screws.
Ben
Ben
Ben
Ben
Post edited by ben62670 on
i hate when i have xtra rubber on my screw............................i aint using no exacto knife, tho!!!!!!!:p
BTW the best company in the world AKA Polk Audio is taking care of it for me.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
This has always been an issue when putting screws thru rubber surrounds. A little trimming is required, or you stand the chance of twisitng the surround under the screw. A lesson learned from early car audio installs when thin butyl surrounds were the norm, not like the thick stuff of today.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I was probably busy finishing my speakers, and missed it. I usually check new post. I bought 14 or 16 woofers, and only damaged four.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I can hook you up with a Mohel who will do a really painless job with no scaring!!!:D -
Dennis Gardner wrote: »This has always been an issue when putting screws thru rubber surrounds. A little trimming is required, or you stand the chance of twisitng the surround under the screw. A lesson learned from early car audio installs when thin butyl surrounds were the norm, not like the thick stuff of today.
I had to trim back some surround from the drivers when I rebuilt my 10A's. I too have twisted many a surround back in the day when in a hurry.
Patience Pays Off. And thanks for the tips Polk Folks.
