Cable suggestions
daboyz
daboyz Posts: 5,207
Looking to replace my Monster sub cable and was looking for any thoughts out there and what y'all are using.
Thanks, Dave
Post edited by daboyz on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    Speaker, or IC?
    Ben
  • daboyz
    daboyz Posts: 5,207
    edited June 2007
    Was looking for IC.
  • ben62670
    edited June 2007
    For a sub IC you want to find a cable that is very low in capacitance.
    Ben
    edited June 2007
    I have used regular IC's as a sub cable in the past,and liked it alot.Borrow some and alittle trial and error and you'll find what tickles you.
  • dkg999
    dkg999 Posts: 5,647
    edited July 2007
    I like the sub cables from Blue Jeans Cables.
    DKG999
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited July 2007
    I use a Signal Cable sub cable....Looks nice, sounds great...How handy are you with a soldering iron? PM me, I may have a few ideas for you....
  • jwhitakr
    jwhitakr Posts: 568
    edited July 2007
    I replaced my old, generic sub IC with a Bluejeans cable and am happy with the improvement in bass extension.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • miner
    miner Posts: 1,305
    edited July 2007
    www.catcables.com
    GREAT quality for the $$. Thank me later.
  • daboyz
    daboyz Posts: 5,207
    edited July 2007
    A little pricey for my blood, unless you have one to ge rid of cheap to audition?
  • mantis
    mantis Posts: 17,541
    edited July 2007
    Look into Audioquests sub cables. I used to use Kimber kable and made the switch. I'm completely happy with my cables.
    Dan
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    I use monoprice premium cables.
    engtaz
