Lsi9's
PolkFan1
PolkFan1 Posts: 130
edited July 2007 in 2 Channel Audio
I am thinking about purchasing some lsi9's over my current rti8's for music because these 8's seem too bright and have too much gain on the high end. Just seems as though they sound too unrealistic sounding. I was using a HK3480.
Now I cannot hear any lsi9's around where I live so I am relying on you people to help me make the right choice. I am sure these will do fine for 2 channel music from all the reviews I have read. Sooo...I am sure a harman Kardon 3480 reciever won't be good enough so I was thinking of getting a amp an pre amp...which one I have no clue and I need some recommendation.
Post edited by PolkFan1 on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    You should love the 9's over your RTi's. An amp is definitely in order to get real good sound. I would keep your 3840 as a pre. My HK served me very well as a pre. Look on www.Audiogon.com for an adcom GFA-555. There are a couple there right now at good prices. Also check Ebay. They can be had for under $350 all day long.
    Enjoy
    Ben
    Ben
  • PolkFan1
    PolkFan1 Posts: 130
    edited June 2007
    I knew someone would say gfa-555. Some people said I should switch the HK for a pre amp. Does it really make a difference? The HK is a 2 channel amp anyways and not a a/v receiver. So it shouldn't be too bad?
    It seems as though that Adcom is real popular and has lots of power? What is it...300 watts x 2 into the 4 ohm lsi9's?
  • engtaz
    engtaz Posts: 7,672
    edited June 2007
    I love my Denon 4802 over 100 watts per channel but I now run external amps and what a difference it makes.
    engtaz
  • PolkFan1
    PolkFan1 Posts: 130
    edited June 2007
    Is it more fuller sounding or just louder?
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited June 2007
    Changes? Try added detail and richness. For what its worth, HK are, for whatever reason, not a good matchup. They sound very dark/veiled. I preferred my RT800 to my LSi's on HK amplification. Of the reasonably priced amps (<$500) that I've used Carver amps sound the best with the LSi's, especially if you're having issues with brightness.
    If it was my money, I would get a workhorse Carver and try it with your RTi's and if that doesn't give you enough relief, look to the LSi's.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • ben62670
    edited June 2007
    PolkFan1 wrote: »
    Your present HK is currant limiting in 4ohm mode if it even has it. I have checked them out, and on the back it says 8ohms for the speakers. I would try your HK as a pre. You can upgrade to something different later. Also checkout Parasound. They are built to very high quality also. Audiogon has some at very reasonable prices.
    Ben
  • engtaz
    engtaz Posts: 7,672
    edited June 2007
    Fuller sound.
    engtaz
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I have a 3480. I'm sure you can try the LSi9s out on it to see if you like how the speakers sound. Won't hurt the amp or the speakers unless you go nuts with the volume. It is rated at 150 wpc into 4 ohms.
    Then, once you add an external amp, it will sound that much better.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • PolkFan1
    PolkFan1 Posts: 130
    edited June 2007
    Ok, any other good pre amps I should look into? I really wanna make this a all in one kinda thing so if the HK isn't going to serve me well beacause it just says 8 ohms on the back then lemme know so i can save time wihtout having to get something else.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited June 2007
    PolkFan1 wrote: »
    H9 was just over and brought his (now DKG999's) LSi9's. The setup was... JVC DVD player to Entech Numbercruncher DAC to HK AVR635 6 channel direct input to ADCOM GFA-555 to the LSI9's.
    It sounded amazing. The H/K seems to make a pretty good pre-amp.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
    The lsi9's are good for all types of music? I do not really listen to jazz or that classical soothing stuff with all of you know but more modern music - pop rock rap all that stuff.
  • skipf
    skipf Posts: 694
    edited July 2007
    LSi-9's are great for any type of music you want to hear clearly. I play classical, rock, blues, jazz and bluegrass thru mine. All sound excellent. I highly recommend the Carver C-1 pre - M-500t amp setup I'm using with my 9's. Very smooth and musical combination. The M-500t doesn't even tremble under the 4 ohm loads many amps have a problem with.
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
    Hmm...How would the Nad c162/c272 preamp/amp combo do with the lsi9's? Seems like the adcom gfa-555 is more powerful though.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2007
    I like NAD very much, they are most definetely my favorite over the other high power/lower cost options. Well, I suppose I would put Parasound right there also.
    I would also recommend Balanced Audio Technology after which you can sit back and enjoy whatever speaker you want for a very long long time.
    As far as specs there are numerous threads about watt ratings and how all watts are not created equal or how a watt rating is not an indication of how an amplifier will pass the signal it has amplified along to a speaker and what it will sound like, buy whatever you think will do it for you but buy informed. I would not recommend getting caught up in the flavor of the month or even year.
    RT1
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
    Well here is my current option plans for my lsi9 setup.
    Option 1-Adcom Gfa-555 amp with Harman Kardon HK3480 as a preamp
    Option 2-Parasound Halo P3 preamp and Adcom Gfa-555 amp
    Option 3-Nad c162/c272 preamp/amp
    Need a little more advice as I cannot test these aout anywhere where I live or no what to expect with a preamp vs. without one. I am going to go solely off of reviews and advice. I also just might scrap the pre amps and get a quality cd player. I do have a budget and I think a quality cd player with option 1 should be good unless I am mistaken.
  • PolkFan1
    PolkFan1 Posts: 130
    edited July 2007
    Based on my budget I think I will do this...
    Nad c542 Cd player
    Harman Kardon hk3480 as a preamp
    Adcom Gfa-555 amp
    lsi9's
    Think this will make a killer 2channel stereo while not breakin the bank? by the way I am buying all used!!!!!!
    I must obtain good sound Yess!!!!!
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2007
    That will be an excellent system!
  • G-2
    G-2 Posts: 533
    edited July 2007
    engtaz wrote: »
    +1000-Richness & fullness will increase significantly, lots of options, you've got most of the info you need to move forward, good luck and enjoy!!
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
