Component Video turns TV RED?
cambir
cambir Posts: 1,046
Please HELP! :confused:
When I connect my DVD to my TV with a component video cable, the picture becomes various shades of RED (not too fun to watch :( ). I would think this is due to hooking up one of the 3 cables wrong, but I've checked them a dozen times and tried a different cable with the same result.
Does anyone know what's causing this or how to fix it? Is it possible one of my terminals is colored wrong?
I have also tried component video from DVD to receiver and HDMI from receiver to TV to take advantage of a claimed "upconvert" feature...I get no picture with this option.
Post edited by cambir on
  • engtaz
    engtaz Posts: 7,674
    edited June 2007
    Make sure all cables are fully seated and the right colors are matched. Allot of people mix up green and blue.
    engtaz
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2007
    Switch progressive off (or on if it's currently off)
  • polkatese
    polkatese Posts: 6,767
    edited June 2007
    your second part, it won't work. Most receiver connectivity require you to connect in straight path (i.e. if you start with component from source to AVR, then you need component from AVR to TV, and also applies to HDMI). You can't mix them, especially between HDMI (Digital) and Component (Analog).
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • cambir
    cambir Posts: 1,046
    edited June 2007
    On the DVD player? I don't seem to have that option.
  • cambir
    cambir Posts: 1,046
    edited June 2007
    polkatese wrote: »
    It is supposed to upconvert video signals via the monitor out jack, but I see your point with the jump to digital. So it could probably only upconvert s-video to component, but not to HDMI.
  • danger boy
    danger boy Posts: 15,722
    edited June 2007
    i think one of your cables is bad.... prob the blue or green would be my guess... try an new cable and see if the problem is still there.
    PolkFest 2012, who's going>?
  • VXR8
    VXR8 Posts: 291
    edited June 2007
    You also can check that your DVD player is set to Component out (may be YUV, YPbPr, YCbCr for the output) in the set up menu? Worth a look?
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • cambir
    cambir Posts: 1,046
    edited June 2007
    Thanks for all the responses.
    OK, so I've got it working with s-vid from dvd to avr and component from avr to tv via the upconvert monitor out. I guess this is the best quality video I can get until I buy a dvd player with HDMI?
    the good news...it's not the cables
    the bad news...still don't know why it didn't work going component from dvd to tv
  • engtaz
    engtaz Posts: 7,674
    edited June 2007
    Any time you get a prominent color with component cables it is because the cables are swapped or open/not connected. How do you know the component cables are good?
    Good Luck
    engtaz
  • cambir
    cambir Posts: 1,046
    edited June 2007
    engtaz wrote: »
    Good Luck
    The cables are good, because I now have it in use from the avr to the tv. It only seems to have the problem if I use it from the dvd to the tv.
  • danger boy
    edited June 2007
    what kind of DVD player are you using? it may have a bad component output RCA
    there is a nice difference in PQ using component over S-video. but at least you got it working. that's the big thing.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    I have had the same problem when I hooked up my brand new DVD player via component to my TV (worked via S-video). You need to go to setup menu of your DVD player and set output to either 'component progressive' or 'component interlaced'. Basically, switch output from S-video to Component. Worked for me.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • dane_peterson
    edited June 2007
    Like I said, turn off progressive. :)
