Dualing Subs
seeclear
seeclear Posts: 1,244
This is probably a stoopid noob question, but I have been dreaming of doing a DIY sonosub to go with my existing sub. My AV receiver (onkyo 504) has a LFE-out RCA jack, so would I just "Y" off of that and cable to each sub? Is there any other way to do it to 2 individually amped subs?
Thanks for playing.;)
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Post edited by seeclear on
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Y off is correct. There are other way like having a sub control. I prefer the Y method
    engtaz
  • Face
    Face Posts: 14,340
    edited June 2007
    If the two subs are to be near each other, I'd run the Y off one of the subs, that'll shorten the amount of cable needed.
