Oppo 970 DTS, SACD Config Question
fatchowmein
fatchowmein Posts: 2,637
edited June 2007 in Electronics
Having issue with the Oppo 970. If I set the HDMI cable for audio, DTS doesn't get passed through. If I hook up a SPDIFF (coaxial), DTS works but no SACD.
Is this a firmware issue or did I screw up the onscreen configuration? I'd hate to have to plug/unplug the coaxial and change the HDMI setting everytime I go from movie to SACD and vice-versa.
In other words, is there anybody out there only using the HDMI cable and getting both DTS and SACD?
Post edited by fatchowmein on
  • fatchowmein
    edited June 2007
    Okay. Looks like my friend and I are only able to get the oppo to play DTS NEO 6 with only the HDMI cable hooked up to his Harmon AVR-347. Connecting the coaxial will yield DTS Digital but SACD is off.
    F1nut Posts: 52,001
    edited June 2007
    Don't hold me to it, but I think SACD can only be passed thru the analog cables on that unit.
  • fatchowmein
    edited June 2007
    You are correct, sir. The problem is if you're using the Oppo to play SACD and DTS DVD movies. When in that configuration (analog/HDMI only), you only get DTS emulation (NEO 6).
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2007
    My 971 is DVD A only via analog. In the setup menus, you set spdif to RAW, DVD A to 5..1 and the player auto detects which type of signal. For movies playback on the HK is DVD, for DVD A 6/8 channel direct. I'd think the 970 would be similar.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • fatchowmein
    edited June 2007
    Ron Temple wrote: »
    Hey Ron,
    Those are my exact settings.
