crossover question/problem
Jockos
If any of the components on say my 11T's were not making a solid connection; say a capacitor, inductor, resistor would just the sound change or would there be no sound at all? I had to do a lot of tugging and pulling to get the old capacitors out because all the glue I used. I could actually here the PCB creaking abit. The large inductor wire broke off so I had to resolder it back to the CB. Is the red color some sort of enamel? I'm just hoping I made a solid joint.
Jockos
Jockos
Post edited by Jockos on
I think that the wire coming from the inductor to the crossover may be your problem. When I did my 11T's, I had the same issue. It's frustrating,but take your time,you'll get it figured out. Good luck,,and yes,, if it is not making the proper connection to the board,the speakers will sound ,,, muted,,for lack of a better description.JC approves....he told me so. (F-1 nut)
Is the red color on the inductor wire some sort of coating, and can you just apply solder straight to it? If it is a coating will it burn off exposing the copper? Or do you have to sand it off. Looking at the schematics it looks as though if the inductor wire did not make contact with the CB there would be no sound at all; am I correct?
The red color is a coating. You can scrape it off with a sharp knife, etc. No contact, no workie.
Tip: To remove hot glue, carefully cut at it with a very sharp razor or knife, then peel away as much as possible before trying to remove the component. Never yank, tug or pull on the components.Political Correctness'.........defined
President of Club Polk -
Thanks F1 so I guess I do have proper contact because it's working.
OK so after looking at some other clearer schematics it looks like if the large inductor doesn't have good connection there would be no sound from the bass drivers. On the tweeter circuit it looks as though if the inductor was not connected, there would still be sound but degraded sound. Does this sound right? Just trying to understand.
Jockos -
anyone?
from my experience,,I would say yes, you are correct. good luck.JC approves....he told me so. (F-1 nut)
I haven't looked at the schematic, but if you soldered that inductor without scraping the enamel off really well then that very well could be the source of your problem. The enamel won't burn off easily when you heat it with an iron- you need to scrape it off with a knife or sandpaper, etc.. Depending on the crossover it might be possible to have the signal feed back through another path and pass to the driver, even though the solder joint on the inductor might not be making contact.
Are your crossovers like the original 11T or the revised schematic? (I looked at those posted under "Troubleshooting") On the revised schematic it looks as if there would be no sound from the MW if the inductor connection was bad. But on the original design, I think there would be sound,..just not right.
Yes mine is the newer(revised) schematic. Thanks. My next suspect would be the smaller inductor for the tweeter. I'm wondering if anyone has had experience with the sound change if it was not connected properly. I would just resolder those joints but that enamel wire looks fragile, and in my experience resoldering these is a delicate job, so I would rather avoid this if posssible.
Thanks,
Jockos -
Thanks,
Jockos
Don't worry about the wire. Take the inductors off, and clean the ends with fine sandpaper till they are nice and shinny. If you don't make sure they are proerly cleaned then you will find yourself running in circles.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I resoldered the inductor wires of both the woofer and tweeter circuits with silver solder. Both speakers sound great. By the way as an experiment I took the woofer inductor wire out and tried hooking it up; no sound out of both bass drivers.
Jockos -
i keep a **** old soldering iron around for that... heat up the glue with the iron and scrape it away as you draw the iron along... if you go and cut the hot glue while it is cold and dry, and then try to pull it out (hence the 'don't yank' warning for F1nut) you may very well rip the trace off the pcb, depending on how much of a piece of crap the pcb is or how strong the hot glue is.The Artist formerly known as PoweredByDodge -
Ripping off the trace would be of concern if the hot glue was on the trace side of the board. However, with these crossovers that is not the case as the mount side of the board is completely trace free.Political Correctness'.........defined
I did use that method where I could.
Jockos -
I have a pair of SDA SRS speakers looking for info on crossover rebuild
Lots of info in this topic. You can try searching.
Here's one thread: http://www.polkaudio.com/forums/showthread.php?t=19053
